01-27-2012 07:31 AM - edited 03-16-2019 09:15 AM
My ip phone register with Router SRST, but the CUCM cannot to register the same ip phone...
- SRST was created with the ip 10.100.5.1 (IP of the remote router)
- Trunk h323 is working with device pool SRST
- device phone is with device pool SRST
I have a 2801 with:
telephony-service
01-27-2012 07:32 AM
The network is ok...
The router and switch "ping" the CUCM
CUCM "ping" without problems the router and switch
01-27-2012 08:01 AM
Can you post your entire "telephony-service" config?
Do you have "max-dn" command under it?
Alos, when you browse to the IP address of the phone do you see the SRST IP address as one of the CM servers referenced?
Chris
01-27-2012 08:54 AM
Hello Chris,
I put the "ip helper addres" in the local interface and it is working right now!! thanks!!
