Ip phone no ring out
soaliou123
Hi guys,
All my ip phones registered with cucm and I am using H.323. The problem is when I dial a pstn number (10 digits ) the ip phone doesn't ring out at all but when I receive a call from a pstn number it rings fine. Also when I call an internal number 1XXX it rings out but not the pstn number.
Any idea?
12 Replies 12
Ayodeji Okanlawon
Can you send your config..
Make sure you have the ff in bold in your config.
conf t
voice call send-alert
and the progress setup and alert under dialpeer
dial-peer voice 1001 pots
progress_ind setup enable 3
progress_ind alert enable 8
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Yes I already put those commands in the voice router
voice translation-rule 2
rule 1 /2..../ /17772821359/
voice translation-rule 3
rule 1 /1678279\(....\)/ /2\1/
voice translation-rule 4
voice translation-rule 5
rule 1 /17772821359/ /2000/
voice translation-rule 100
rule 1 /1777282\(....\)/ /\1/
rule 2 /16782794482/ /17772821359/
voice translation-rule 105
rule 1 /1359/ /17772821359/
rule 2 /1359/ /16782794482/
voice translation-profile PSTN_in
translate called 100
voice translation-profile PSTN_out
translate calling 105
voice translation-profile TRANSLATE
translate calling 5
dial-peer voice 10000 voip
description Ways to 1XXX
translation-profile outgoing PSTN_in
destination-pattern 1...
session target ipv4:172.16.2.10
dial-peer voice 10001 voip
description call to PSTN network
translation-profile outgoing PSTN_out
destination-pattern 1[2-9]..[2-9]......
voice-class codec 1
session protocol sipv2
session target dns:callcentric.com
dtmf-relay sip-notify rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
So this is a SIP based PSTN.
Can you do a test call and send the ff debugs
debug ccsip messsages
debug voip ccapi inout
I also observe that there is no inbound dialpeer from cucm to the gateway..
Can you add this
dial-peer voice xxx voip
incoming called-number (put your called pattern here)
dtmf-relay h245 alpha-num
no vad
I didn't copy that part
OK. What is your call flow..Is this correct?
CUCM---h323--CUBE---SIp---PSTN
If thats correct you  need to define an inbound dial-peer for calls coming in from cucm to the gateway (thse calls ar then sent tto the PSTN by the gateway)
I noticed that you have sip setup for your outbound dial-peer to your PSTN but there is no inbound dial-peer from CUCM
The ip phone rings out fine when I dial international number 011T. Only the pstn number 10 digits no ring out. Anything else works fine
OK,
If you need help then you need send the information requested..
Please send 'debug voip ccapi inout' and 'debug csip messages' for the affected calls.
2651xm#debug voip ccapi inout
voip ccapi inout debugging is on
2651xm#
Mar 10 17:24:40.973: //-1/007ED19C3700/DPM/dpAssociateIncomingPeerCore:
   Calling Number=1359, Called Number=16785232243, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
Mar 10 17:24:40.977: //-1/007ED19C3700/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=102
Mar 10 17:24:40.977: //-1/007ED19C3700/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=1359
   ----- ccCallInfo IE subfields ---
2651xm#--
   cisco-ani=1359
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=16785232243
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Mar 10 17:24:40.981: //-1/007ED19C3700/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x8682AEF0, Call Info(
   Calling Number=1359,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=16785232243(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=102, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=174
Mar 10 17:24:40.981: //-1/007ED19C3700/CCAPI/ccCheckClipClir:
   In: Calling Number=1359(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Mar 10 17:24:40.985: //-1/007ED19C3700/CCAPI/ccCheckClipClir:
   Out: Calling Number=1359(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Mar 10 17:24:40.985: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 10 17:24:40.985: :cc_get_feature_vsa malloc success
Mar 10 17:24:40.985:  cc_get_feature_vsa count is 1
Mar 10 17:24:40.985: :FEATURE_VSA attributes are: feature_name:0,fearture_time:2252809584,feature_id:166
Mar 10 17:24:40.985: //174/007ED19C3700/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=1359(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=16785232243(TON=Unknown, NPI=Unknown))
Mar 10 17:24:40.989: //174/007ED19C3700/CCAPI/cc_process_call_setup_ind:
   Event=0x86490D78
Mar 10 17:24:40.989: //174/007ED19C3700/CCAPI/ccCallSetContext:
   Context=0x86A9398C
Mar 10 17:24:40.993: //174/007ED19C3700/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 174 with tag 102 to app "_ManagedAppProcess_Default"
Mar 10 17:24:40.993: //174/007ED19C3700/CCAPI/ccCallProceeding:
Mar 10 17:24:40.997: //-1/007ED19C3700/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=16785232243, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=16785232243
   Result=Success(0) after DP_MATCH_DEST
Mar 10 17:24:41.001: //-1/007ED19C3700/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=10001
     2: Dial-peer Tag=10000
Mar 10 17:24:41.001: //174/007ED19C3700/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=10001, Params=0x86A96184, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar 10 17:24:41.001: //174/007ED19C3700/CCAPI/ccCheckClipClir:
   In: Calling Number=17772821359(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Mar 10 17:24:41.005: //174/007ED19C3700/CCAPI/ccCheckClipClir:
   Out: Calling Number=17772821359(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Mar 10 17:24:41.005: //174/007ED19C3700/CCAPI/ccCallSetupRequest:
   Destination Pattern=1[2-9]..[2-9]......, Called Number=16785232243, Digit Strip=FALSE
   Calling Number=17772821359(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Redirect Number=, Display Info=
   Account Number=1359, Final Destination Flag=TRUE,
   Guid=007ED19C-D57E-F114-3700-3801AC10020C, Outgoing Dial-peer=10001
Mar 10 17:24:41.005: //174/007ED19C3700/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=1359
   ----- ccCallInfo IE subfields -----
   cisco-ani=17772821359
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=16785232243
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Mar 10 17:24:41.013: //174/007ED19C3700/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x867AA2D4, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=17772821359,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=16785232243(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar 10 17:24:41.013: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 10 17:24:41.017: :cc_get_feature_vsa malloc success
Mar 10 17:24:41.017: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 10 17:24:41.017:  cc_get_feature_vsa count is 2
Mar 10 17:24:41.017: :FEATURE_VSA attributes are: feature_name:0,fearture_time:2252807856,feature_id:167
Mar 10 17:24:41.017: //175/007ED19C3700/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Mar 10 17:24:41.021: //175/007ED19C3700/CCAPI/ccCallSetContext:
   Context=0x86A96134
Mar 10 17:24:41.021: //174/007ED19C3700/CCAPI/ccSaveDialpeerTag:
Mar 10 17:24:41.025: //175/007ED19C3700/CCAPI/cc_api_call_proceeding:
   Interface=0x867AA2D4, Progress Indication=NULL(0)
2651xm#
2651xm#
Mar 10 17:24:54.512: //174/007ED19C3700/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x8682AEF0, Call Id=174
   Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Mar 10 17:24:54.516: //175/007ED19C3700/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=FALSE, Cause Value=16)
Mar 10 17:24:54.520: //174/007ED19C3700/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Mar 10 17:24:54.520: //174/007ED19C3700/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Mar 10 17:24:54.532: //174/007ED19C3700/CCAPI/cc_api_call_disconnec
2651xm#t_done:
   Disposition=0, Interface=0x8682AEF0, Tag=0x0, Call Id=174,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Mar 10 17:24:54.532: //174/007ED19C3700/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
Mar 10 17:24:54.536: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 10 17:24:54.536: :cc_free_feature_vsa freeing 86472568
Mar 10 17:24:54.536:  vsacount in free is 1
Mar 10 17:24:54.592: //175/007ED19C3700/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x867AA2D4, Tag=0x0, Call Id=175,
Mar 10 17:24:54.592: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 10 17:24:54.592: :cc_free_feature_vsa freeing 86471EA8
Mar 10 17:24:54.592:  vsacount in free is 0
2651xm#debug ccsip messages
SIP Call messages tracing is enabled
2651xm#
Mar 10 17:26:30.375: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:16785232243@callcentric.com:5080 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.7:5060;branch=z9hG4bK8415E5
Remote-Party-ID: <>17772821359@callcentric.com>;party=calling;screen=yes;privacy=off
From: <>17772821359@callcentric.com>;tag=D66E3-1E4C
To: <>16785232243@callcentric.com>
Date: Sun, 10 Mar 2013 17:26:30 GMT
Call-ID: 7B15CAB9-88DE11E2-80EDBF05-C0F9C20@callcentric.com
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 2712286-1132458260-939538689-2886730252
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1362936390
Contact: <17772821359>
Call-Info: <192.168.0.7:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: telephone-event
Content-Length: 0
2651xm#
Mar 10 17:26:30.452: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
v: SIP/2.0/UDP 192.168.0.7:5060;branch=z9hG4bK8415E5;rport=57448;received=64.203.215.226
f: <>17772821359@callcentric.com>;tag=D66E3-1E4C
t: <>16785232243@callcentric.com>
i: 7B15CAB9-88DE11E2-80EDBF05-C0F9C20@callcentric.com
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="callcentric.com", domain="sip:callcentric.com", nonce="e38404538e671908fe60e1598cf18cc6", opaque="", stale=TRUE, algorithm=MD5
l: 0
Mar 10 17:26:30.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:16785232243@callcentric.com:5080 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 192.168.0.7:5060;branch=z9hG4bK8526AE
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Proxy-Authorization: Digest username="17772821359",realm="callcentric.com",uri="sip:16785232243@callcentric.com:5080",response="f3449e7654bd0b4e279540fdfdbc4850",nonce="e38404538e671908fe60e1598cf18cc6",opaque="",algorithm=MD5
Content-Length: 0
Mar 10 17:26:30.524: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
v: SIP/2.0/UDP 192.168.0.7:5060;branch=z9hG4bK8526AE;rport=57448;received=64.203.215.226
CSeq: 102 INVITE
l: 0
Mar 10 17:26:30.752: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 102 INVITE
l: 0
2651xm#
2651xm#
Mar 10 17:26:35.913: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
t: <>16785232243@callcentric.com>;tag=3573153219-717879
CSeq: 102 INVITE
m: <7BF4BF8CB1B62FC5AB23269E8F440964>
l: 0
2651xm#
Mar 10 17:26:36.418: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
l: 0
2651xm#
Mar 10 17:26:37.419: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
l: 0
2651xm#
Mar 10 17:26:39.415: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
l: 0
2651xm#
Mar 10 17:26:43.417: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
l: 0
Mar 10 17:26:44.194: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:16785232243@callcentric.com:5080 SIP/2.0
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1362936404
Reason: Q.850;cause=16
Content-Length: 0
Mar 10 17:26:44.247:
2651xm#//-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 CANCEL
l: 0
Mar 10 17:26:44.259: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Terminated
CSeq: 102 INVITE
l: 0
Mar 10 17:26:44.267: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <>16785232243@callcentric.com>;tag=3573153219-717879
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
session target ipv4:172.16.2.10 CUCM ip address
voice-class codec 1
I am doing digits manipulation on 1XXX-------------->1XXXXXXXXXX
Can you please send your full config. I can see the call is matching inbound dialpeer 102. But I dont know what you have on that dialpeer...
I have cucm10.5 with 2x2921 routers.
When I place an internal call I don't here the ring and i don't now how many times the call is ringing.
Any ideas why my cucm doesn't  send the ring to the other terminal???
Aman Soi
What u are trying to say is that u have a cisco router configured as H.323 GW on which is being used for PSTN and registered to Call Manager.
The problem u are facing is that when u are dialing from IP phone to PSTN number , u do not hear RingBack Tone on your IP phone but the call when picked by PSTN user, u are able to talk.
When PSTN user calls on your IP phone, it works perfectly fine.
Please explain the last line of internal number.
regds,
aman
Yes. I have a couple of ip phones registered to cucm( v8.6). When I call the other ip phone internal number 1XXX it rings out. But When I dial a PSTN number number like my cell phone no ring out but I still receive the call from the ip phone.
Also I see the incoming call to my ip phone but I can't hear anything when I answer it and the other end they hear a fast busy signal.
