12-21-2016 02:30 AM - edited 03-17-2019 09:00 AM
Hi, everyone, this is first time i am using this, so I don't know where I submit enough information or not. thanks first. The question is: we have been using UC540W for a long time, now we bought two new IP Phones(7821), the new IP Phones can be registered with UC540W or not, thanks again.
This is hardware information:
VCSGOFCUC540#show version
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(4)M5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 04-Sep-12 20:45 by prod_rel_team
ROM: System Bootstrap, Version 12.4(24r)SB, RELEASE SOFTWARE (fc1)
VCSGOFCUC540 uptime is 2 hours, 13 minutes
System returned to ROM by reload at 11:56:17 SG Fri Dec 16 2016
System restarted at 11:57:10 SG Fri Dec 16 2016
System image file is "flash:/uc500-advipservicesk9-mz.151-4.M5"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco UC540W-FXO-K9 (MPC8358) processor (revision 0x100) with 235520K/26624K bytes of memory.
Processor board ID FGL170920M5
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x20
30 User Licenses
10 FastEthernet interfaces
11 Serial interfaces
2 terminal lines
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 802.11 Radio
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 UC540W-FXO-K9 FGL172920M3
VCSGOFCUC540#show inventory
NAME: "UC540W-FXO-K9 Chassis", DESCR: "UC540W-FXO-K9 Chassis"
PID: UC540W-FXO-K9 , VID: V01, SN: FGL172920M3
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 in DaughterCard Slot 2", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1 , VID: V01 , SN: FOC11190A5S
12-21-2016 03:19 AM
Hi Jiangbo,
UC540 supports the following phone models:
Choice of Cisco Unified IP Phones 6900 and 7900 Series and Cisco Small Business SPA Series IP Phones, including wireless handsets and Session Initiation Protocol (SIP) phones.
More details here
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unity-express/data_sheet_c78-554289.html
You may consider looking at the BE6000 or CUCME solution for supporting these new phones by checking their datasheets to start with.
Manish
