06-21-2021 04:07 AM
I have configured 3, 8851 Ip phones on a router. When I reboot the router only one phone registers. The other two do not and and display the message Unprovisioned. The will register if I go into the router and use the command voice register global/ create profile. I cant seem to figure out what I am doing wrong...
Solved! Go to Solution.
06-21-2021 04:16 AM
You need to do "create Profile" by under voice register global when ever you make any changes or adding new phones.
Also Make sure you add the correct mac address for voice register pools.
06-21-2021 04:50 AM
Ok I'm pretty sure I did that, but will redo the the profile and issue that command. I'll also check the MAC address. Thank you and I'll get back to you..
06-21-2021 11:25 AM
I am doing all of this through CLI
I understand after each change to the profile change, I need to use the Voice register global / create profile command to save the changes. I'm still having a hard time getting the phone to update. If I can get it see the updated firmware. Its taking the config because I have to enter a password to get into the setting. My biggest problem I feel Is I'm not understanding how to get the phone to update to the newest firmware
06-21-2021 07:30 PM
06-23-2021 10:52 AM
I do that once I get past this registration hurtle... Love the help though I would be totally lost without you guys...
06-21-2021 04:16 AM
06-21-2021 04:50 AM
06-21-2021 11:25 AM
06-21-2021 07:30 PM
06-23-2021 10:52 AM
