06-09-2011 05:57 AM - edited 03-16-2019 05:21 AM
..with any connect of course.
Does it really work?
Does anybody made it?
I have found some "configuration steps" here at the community but they are not so helpful..
I am trying to make this feature work with no result.
I have all the supported equipment, the proper licenses etc!
The vpn works with my laptop but not with the 7945.
Can I find somewhere any config guide for dummies?
06-09-2011 11:31 PM
anybody?
06-10-2011 08:43 AM
I've made a configuration document based on the CUCM side, so if you want to check that out please feel free.
Ryan
06-20-2011 04:58 AM
Hello and thanks,
I just need the exact configuration steps that I have to do on ASA..
06-20-2011 06:44 AM
Anybody knows?
06-28-2011 12:56 AM
Hello!!
Anybody?
Has anybody managed to make this play?
06-28-2011 06:25 AM
Can you provide the ASA configuration that you currently have?
I guess this is what you are looking for:
https://supportforums.cisco.com/docs/DOC-9124
Luis Sandi
