IP Phone SSL VPN to ASA
derveniss
..with any connect of course.
Does it really work?
Does anybody made it?
I have found some "configuration steps" here at the community but they are not so helpful..
I am trying to make this feature work with no result.
I have all the supported equipment, the proper licenses etc!
The vpn works with my laptop but not with the 7945.
Can I find somewhere any config guide for dummies?
6 Replies 6
derveniss
anybody?
I've made a configuration document based on the CUCM side, so if you want to check that out please feel free.
Ryan
Hello and thanks,
I just need the exact configuration steps that I have to do on ASA..
Anybody knows?
derveniss
Hello!!
Anybody?
Has anybody managed to make this play?
Can you provide the ASA configuration that you currently have?
I guess this is what you are looking for:
https://supportforums.cisco.com/docs/DOC-9124
Luis Sandi
