IP phones default gateway issue
I have a problem with my IP phones default Gateway.
In my network I have one firewall which used for routing, and a router CCME. I have configured DHCP network for my IP phones in my CCME, but my CCME can't communicate  with a firewall. I think it is a default Gateway issue.
How can I configure the router CCME for gain communication with a firewall.
Below you can see the configuration of DHCP for IP phones:
ip dhcp pool voice
 network 10.19.51.0 255.255.255.0
 default-router 10.19.51.1
 option 150 ip 10.19.51.3
 dns-server 158.113.41.123
 lease 0 7
You can see the architecture in attached.
Best Regards,
Aristide
6 Replies 6
Dennis Mink
Mate,
I think you are mixing things up.  Can you ping  10.19.51. from your CME router?
also are the phones registered?
As far as I can see all the CME router needs is  a default gateway, pointing to the firewall.
Please remember to rate useful posts, by clicking on the stars below.
Hi Dennis,
I can't ping 10.19.51.1 from my CME.
All phones are registered with ip address 10.19.51.X
what configuration I have to do to point my CME to the firewall?
Aristide
Please share the router and switch config. Also,  indicate the port of the phone
Hi Mohammed,
You can see below the router and the switch configuration.
Router configuration
UNICEF-Conakry(config)#do sh run
Building configuration...
Current configuration : 33488 bytes
! Last configuration change at 11:07:58 UTC Mon Oct 12 2015 by Unicef
version 15.4
hostname UNICEF-Conakry
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
enable secret 5 $1$MHWz$Oxo9JXwzlpN7YwqH9u6Y21
no aaa new-model
clock calendar-valid
network-clock-participate wic 0
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.19.51.1 10.19.51.20
ip dhcp ping packets 10
ip dhcp pool ccp-pool
 network 10.10.10.0 255.255.255.248
 default-router 10.10.10.1
ip dhcp pool voice
 lease 0 7
ip domain name unicef.org
ip cef
no ipv6 cef
isdn switch-type primary-net5
trunk group PSTN
 hunt-scheme longest-idle
 lpcor outgoing PSTNTrunk
cts logging verbose
crypto pki trustpoint TP-self-signed-980392006
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-980392006
 revocation-check none
 rsakeypair TP-self-signed-980392006
crypto pki certificate chain TP-self-signed-980392006
 certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 39383033 39323030 36301E17 0D313431 32313330 34333331
  385A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3938 30333932
  30303630 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  BA624D49 CAAD2CF4 02132C9F DA3DF5C6 24B97E0D BCE1A0B3 BEDE8758 434BDBAA
  65F5552A 004C5C21 3717FB18 B54EEC96 4D8EAF36 C87A35A1 53C5F65D ED15BAAD
  CD47F8E5 CEB5E45E ACA77C37 272837C8 045A18B9 489719CA 38F066A2 270E8EAC
  5865899D AB1277B9 1FBD5F8D 588CE534 3F167072 0559700C E40BBC6F 9BD9DB35
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 168014DC BB0E25E0 E90B1CF1 B6DE5260 D82BA04C 6C36D730 1D060355
  1D0E0416 0414DCBB 0E25E0E9 0B1CF1B6 DE5260D8 2BA04C6C 36D7300D 06092A86
  4886F70D 01010505 00038181 003D7D12 D1A5F779 6A6A3082 4697B285 A5C49F7C
  65E255E8 DF24844D EF951F7F 481AFECA A498DDC9 165F743D 91415521 C8EA8003
  E7539330 2DEF562D 6ECBD4F0 60E68192 CDE699A4 E44B4AA9 3AEF2426 880281E8
  FA53FF02 860F3673 49460F44 C9843FB4 91287FF4 E30EC679 40175D2F 533F2E16
  FAEDFF99 FC0743BA 705B0327 EF
        quit
voice-card 0
 dsp services dspfarm
voice service voip
 allow-connections h323 to sip
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind media source-interface GigabitEthernet0/1.20
  registrar server expires max 1200 min 300
voice register global
 mode  cme
 source-address 10.19.51.3 port 5060
 max-dn 400
 max-pool 150
 load 7941 sip78xx.10-1-1SR1-4
 load 7965 cmterm-7945_7965-sip.9-4-2SR1-1.cop.sgn
 load 8945 SIP894x.9-4-2SR1-2
 timezone 20
 dialplan-pattern 1 624931... extension-length 4 extension-pattern 1...
 tftp-path flash:
 file text
 create profile sync 0084114841204528
 ntp-server 131.0.232.2 mode directedbroadcast
 camera
 video
voice register dn  1
 number 1801
 call-forward b2bua busy 1910
 call-forward b2bua noan 1910 timeout 20
 name MOHAMED AYOYA
 label MOHAMED AYOYA REPRESENTANT
voice register dn  2
 number 1802
 call-forward b2bua busy 1911
 call-forward b2bua noan 1911 timeout 20
 name Guy YOGO
 label Guy YOGO Rep.Adjoint
voice register dn  3
 number 1803
 call-forward b2bua busy 1912
 call-forward b2bua noan 1912 timeout 20
voice register dn  4
 number 1804
 name Mariame KABA
 label Mariame KABA
voice register dn  5
 number 1805
 name Mariama Sira DIALLO
 label Mariama Sira DiallO
voice register dn  6
 number 1806
 name Fatoumata Bangoura
 label Fatoumata Bangoura
voice register dn  7
 number 1807
 name Catherine RICHARD
 label Catherine RICHARD
voice register dn  8
 number 1808
 name Daouda DIOP
 label Daouda DIOP Quality Assurance
voice register dn  9
 number 1809
 name Amadou Korka BAH
 label Amadou Korka BAH
voice register dn  10
 number 1810
 name Mahamane ABDOU
 label Mahamane ABDOU Field Security
voice register dn  11
 number 1811
 name Ousmane Fatoumata CAMARA
 label Ousmane F. CAMARA
voice register dn  12
 number 1812
 name SEYDOU DIA
 label SEYDOU DIA EMERGENCY
voice register dn  13
 number 1813
 name Moise TOUNKARA
 label Moise TOUNKARA
voice register dn  14
 number 1814
 name TIMOTHY LA ROSE
 label TIMOTHY LA ROSE Communication
voice register dn  15
 number 1815
 name Kadijah DIALLO
 label Kadijah DIALLO
voice register dn  16
 number 1816
 name Claude-Adrien
 label Claude-Adrien
voice register dn  17
 number 1817
 name Lianne GUTCHER
 label Lianne GUTCHER
voice register dn  18
 number 1818
 name Standard
 label Saran Madeleine ONIVOGUI
voice register dn  19
 number 1819
 name Rosemary MUSUMBA
 label Rosemary MUSUMBA
voice register dn  20
 number 1820
 name Mohamed Saidou DIALLO
 label Mohamed Saidou DIALLO
voice register dn  21
 number 1821
 name J-B SENE
 label J-B SENE chief Social Policy
voice register dn  22
 number 1822
 name Emile TENGUIANO
 label Emile TENGUIANO
voice register dn  23
 number 1823
voice register dn  24
 number 1824
 name Tharcienne NDIHOKUBWAYO
 label Tharcienne NDIHOKUBWAYO
voice register dn  25
 number 1825
 name Ibrahim CISSE
 label Ibrahim CISSE
voice register dn  26
 number 1826
 name Mariam DIENE
 label Mariam DIENE
voice register dn  27
 number 1827
 name Moustapha DABO
 label Moustapha DABO
voice register dn  28
 number 1828
 name Linda NSAHTIME-AKONDENG
 label Linda NSAHTIME-AKONDENG
voice register dn  29
 number 1829
 name Kadiatou BALDE
 label Kadiatou BALDE
voice register dn  30
 number 1830
 name Hilaire NINTERETSE
 label Hilaire NINTERETSE
voice register dn  31
 number 1831
 name Ismeal Tata NGNIE
 label Ismael Ngnie Nutrition Spec
voice register dn  32
 number 1832
 name Javier RODRIGUEZ
 label Javier RODRIGUEZ
voice register dn  33
 number 1833
 name Jean Max Beauliere
 label Jean Max Beauliere
voice register dn  34
 number 1834
 name Julien LABAS
 label Julien LABAS Chief Wash
voice register dn  35
 number 1835
 name EL Hadj Mamadou Barry
 label EL Hadj Mamadou Barry
voice register dn  36
 number 1836
 name Thierno CISSE
 label Thierno CISSE
voice register dn  37
 number 1837
 name Tarik HASSAN
 label Tarik HASSAN
voice register dn  38
 number 1838
 call-forward b2bua all 1855
 name Veronique SARR
 label Veronique SARR
voice register dn  39
 number 1839
 name Hady KAMARA
 label Hady KAMARA
voice register dn  40
 number 1840
 name Hassatou DIALLO
 label Hassatou DIALLO
voice register dn  41
 number 1841
 name Gervais HAVYARIMANA
 label Gervais HAVYARIMANA Education
voice register dn  42
 number 1842
 name Mamadou DIALLO
 label Mamadou DIALLO
voice register dn  43
 number 1843
 name Abdoul Kader JOLY
 label Abdoul Kader JOLY
voice register dn  44
 number 1844
 name Geraldeau AGOTHO
 label Geraldeau AGOTHO
voice register dn  45
 number 1845
 name Sarhane M.KHAMIS
 label Sarhane M.KHAMIS
voice register dn  46
 number 1846
 name Guirlene FREDERIC
 label Guirlene FREDERIC child protec
voice register dn  47
 number 1847
 name Julie DUBOIS
 label Julie DUBOIS
voice register dn  48
 number 1848
 name Aicha CONTE
 label Aicha CONTE
voice register dn  49
 number 1849
 name Raymond FOMBA
 label Raymond FOMBA
voice register dn  50
 number 1850
 name Moriba THEA
 label Moriba THEA
voice register dn  51
 number 1851
 name Fily DIALLO
 label Fily DIALLO
voice register dn  52
 number 1852
 name Sarata KABA
 label Sarata KABA
voice register dn  53
 number 1853
 name Kouassi MESSOU
 label Kouassi MESSOU
voice register dn  54
 number 1854
 name Samba DIALLO
 label Samba DIALLO
voice register dn  55
 number 1855
 name Ada POUYE
 label Ada POUYE Chief C4D
voice register dn  56
 number 1856
 name Raby DIOUF
 label Raby DIOUF
voice register dn  57
 number 1857
 name Vincent NKURUNZIZA
 label Vincent NKURUNZIZA
voice register dn  58
 number 1858
 name Mariam TOURE
 label Mariam TOURE
voice register dn  59
 number 1859
 name ALmamy BARRY
 label Almamy BARRY
voice register dn  60
 number 1860
 name Aboubacar DIAKITE
 label Aboubacar DIAKITE
voice register dn  61
 number 1861
voice register dn  62
 number 1862
 name Fatoumata BAH
 label Fatoumata Binta BAH
voice register dn  63
 number 1863
 name Emmanuel YOUMBOUNO
 label Emmanuel YOUMBOUNO
voice register dn  64
 number 1864
 name Aye Bobo DIENG
 label Aye Bobo DIENG
voice register dn  65
 number 1865
 name Yalikha TRAORE
 label Yalikha TRAORE
voice register dn  66
 number 1866
 name Fatoumata BANGOURA
 label Fatoumata BANGOURA
voice register dn  67
 number 1867
 name Mamadou S DIALLO
 label Mamadou S DIALLO
voice register dn  68
 number 1868
 name Mahamat Nour MOLLI
 label Mahamat MOLLI Finance spec
voice register dn  69
 number 1869
 name Sere MAGASSOUBA
 label Sere MAGASSOUBA
voice register dn  70
 number 1870
 name Oumou Sadio BAH
 label Oumou Sadio BAH
voice register dn  71
 number 1871
 name Mamadou Yaya DIALLO
 label Mamadou Yaya DIALLO
voice register dn  72
 number 1872
 name Michael Zanardi
 label Michael Zanardi
voice register dn  73
 number 1873
 name Kadiatou DIALLO
 label Kadiatou DIALLO
voice register dn  74
 number 1874
 name Adama Hawa BALDE
 label Adama Hawa BALDE
voice register dn  75
 number 1875
 name Sekou SOUMAORO
 label Sekou SOUMAORO
voice register dn  76
 number 1876
 name Saran SIDIBE
 label Saran SIDIBE
voice register dn  77
 number 1877
 name Yves MAZARD
 label Yves MAZARD
voice register dn  78
 number 1878
 name Constant OUEDRAOGO
 label Constant OUEDRAOGO
voice register dn  79
 number 1879
 name Irma ALOFA
 label Irma ALOFA
voice register dn  80
 number 1880
 name Ahmed TALL
 label Ahmed TALL
voice register dn  81
 number 1881
 name Ousmane BAH
 label Ousmane BAH
voice register dn  82
 number 1882
 name Fode CAMARA
 label Fode CAMARA
voice register dn  83
 number 1883
 name Kadiatou CONDE
 label Kadiatou CONDE
voice register dn  84
 number 1884
 name Mirabelle De SOUZA
 label Mirabelle De SOUZA
voice register dn  85
 number 1885
 name Mamadou TOURE
 label Mamadou TOURE
voice register dn  86
 number 1886
 name Abdoulaye DIALLO
 label Abdoulaye DIALLO
voice register dn  87
 number 1887
voice register dn  88
 number 1888
 name Administrative Specialist
 label Administrative Specialist
voice register dn  89
 number 1889
 name Amadou Bailo BAH
 label Amadou Bailo BAH
voice register dn  90
 number 1890
 name Mamadou SECK
 label Mamadou SECK
voice register dn  91
 number 1891
 name Samuel N'DIAYE
 label Samuel N'DIAYE
voice register dn  92
 number 1892
voice register dn  93
 number 1893
voice register dn  94
 number 1894
voice register dn  95
 number 1895
voice register dn  96
 number 1896
voice register dn  97
 number 1897
voice register dn  98
 number 1898
voice register dn  99
 number 1899
voice register dn  100
 number 1900
 name DRIVERS
 label DRIVERS
voice register dn  101
 number 1901
 name Madina BAH
 label Madina BAH Chief Office
voice register dn  102
 number 1902
 name Oumou Aliou SOW
 label Oumou Aliou SOW
voice register dn  103
 number 1903
 name Fassou LAMA
 label Fassou LAMA
voice register dn  104
 number 1904
 name Hady CAMARA
 label Hady CAMARA
voice register dn  105
 number 1905
 name Aissatou TOURE
 label Aissatou TOURE
voice register dn  106
 number 1906
 name Fatoumata DIALLO
 label Fatoumata DIALLO
voice register dn  107
 number 1907
 name Mamadou BARRY
 label Mamadou BARRY
voice register dn  108
 number 1908
 name Abdouramane SHERIF
 label Abdouramane SHERIF
voice register dn  121
 number 1990
 name Vigiles
 label Vigiles
voice register pool  1
 busy-trigger-per-button 2
 id mac E0D1.73E1.5815
 type 8945
 number 1 dn 1
 cor incoming local-outside default
 dtmf-relay rtp-nte
voice register pool  2
 id mac E0D1.73E1.574D
 type 8945
 number 1 dn 2
 dtmf-relay rtp-nte
voice register pool  3
 id mac E0D1.73E1.58F3
 type 8945
 number 1 dn 3
 dtmf-relay rtp-nte
voice register pool  4
 id mac E0D1.73E4.2AE5
 type 7841
 number 1 dn 4
 dtmf-relay rtp-nte
voice register pool  5
 id mac E0D1.73E4.2ADC
 type 7841
 number 1 dn 5
 dtmf-relay rtp-nte
voice register pool  6
 id mac 8480.2DD5.EB38
 type 7841
 number 1 dn 6
 dtmf-relay rtp-nte
voice register pool  7
 id mac E0D1.73E4.2AE7
 type 7841
 number 1 dn 7
 dtmf-relay rtp-nte
voice register pool  8
 id mac E0D1.73E1.57AB
 type 8945
 number 1 dn 8
 dtmf-relay rtp-nte
voice register pool  9
 id mac E0D1.73E4.2BA7
 type 7841
 number 1 dn 9
 dtmf-relay rtp-nte
voice register pool  10
 id mac E0D1.73E4.A573
 type 7861
 number 1 dn 10
 dtmf-relay rtp-nte
voice register pool  11
 id mac E0D1.73E4.2AE3
 type 7841
 number 1 dn 11
 dtmf-relay rtp-nte
voice register pool  12
 id mac E0D1.73E4.A54C
 type 7861
 number 1 dn 12
 dtmf-relay rtp-nte
voice register pool  13
 id mac E0D1.73E4.0C58
 type 7841
 number 1 dn 13
 dtmf-relay rtp-nte
voice register pool  14
 id mac E0D1.73E1.57F1
 type 8945
 number 1 dn 14
 dtmf-relay rtp-nte
voice register pool  15
 id mac E0D1.73E4.2AC8
 type 7841
 number 1 dn 15
 dtmf-relay rtp-nte
voice register pool  16
 id mac E0D1.73E4.2ACD
 type 7841
 number 1 dn 16
 dtmf-relay rtp-nte
voice register pool  17
 id mac E0D1.73E4.2AE9
 type 8945
 number 1 dn 17
 dtmf-relay rtp-nte
voice register pool  18
 id mac E0D1.73E4.A43B
 type 7861
 number 1 dn 18
 dtmf-relay rtp-nte
 no vad
voice register pool  19
 id mac E0D1.73E4.0C5F
 type 7841
 number 1 dn 19
 dtmf-relay rtp-nte
voice register pool  20
 id mac E0D1.73E4.0BC1
 type 7841
 number 1 dn 20
 dtmf-relay rtp-nte
voice register pool  21
 id mac E0D1.73E1.57C7
 type 8945
 number 1 dn 21
 dtmf-relay rtp-nte
 dnd
voice register pool  22
 id mac E0D1.73E4.2BB9
 type 7841
 number 1 dn 22
 dtmf-relay rtp-nte
voice register pool  23
 id mac E0D1.73E1.4FE7
 type 8945
 number 1 dn 23
 dtmf-relay rtp-nte
voice register pool  24
 id mac E0D1.73E1.3ECB
 type 8945
 number 1 dn 24
 dtmf-relay rtp-nte
voice register pool  25
 id mac E0D1.73E4.0C89
 type 7841
 number 1 dn 25
 dtmf-relay rtp-nte
voice register pool  26
 id mac E0D1.73E4.2B39
 type 7841
 number 1 dn 26
 dtmf-relay rtp-nte
voice register pool  27
 id mac E0D1.73E4.0B62
 type 7841
 number 1 dn 27
 dtmf-relay rtp-nte
voice register pool  28
 id mac E0D1.73E4.2B80
 type 7841
 number 1 dn 28
 dtmf-relay rtp-nte
voice register pool  29
 id mac E0D1.73E4.2C5A
 type 7841
 number 1 dn 29
 dtmf-relay rtp-nte
voice register pool  30
 id mac E0D1.73E4.2BB0
 type 7841
 number 1 dn 30
 dtmf-relay rtp-nte
voice register pool  31
 id mac E0D1.73E1.5825
 type 8945
 number 1 dn 31
 dtmf-relay rtp-nte
voice register pool  32
 id mac E0D1.73E4.0BD4
 type 7841
 number 1 dn 32
 dtmf-relay rtp-nte
voice register pool  33
 id mac E0D1.73E4.0C2B
 type 8945
 number 1 dn 33
 dtmf-relay rtp-nte
voice register pool  34
 id mac E0D1.73E1.566D
 type 8945
 number 1 dn 34
 dtmf-relay rtp-nte
voice register pool  35
 id mac E0D1.73E4.0C61
 type 8945
 number 1 dn 35
 dtmf-relay rtp-nte
voice register pool  36
 id mac E0D1.73E4.2BC3
 type 7841
 number 1 dn 36
 dtmf-relay rtp-nte
voice register pool  37
 id mac E0D1.73E4.2B2E
 type 7841
 number 1 dn 37
 dtmf-relay rtp-nte
voice register pool  38
 id mac E0D1.73E4.0C36
 type 7841
 number 1 dn 38
 dtmf-relay rtp-nte
voice register pool  39
 id mac E0D1.73E4.0C05
 type 7841
 number 1 dn 39
 dtmf-relay rtp-nte
voice register pool  40
 id mac E0D1.73E4.2BCC
 type 7841
 number 1 dn 40
 dtmf-relay rtp-nte
voice register pool  41
 id mac E0D1.73E1.56D5
 type 8945
 number 1 dn 41
 dtmf-relay rtp-nte
voice register pool  42
 id mac E0D1.73E4.2BBC
 type 7841
 number 1 dn 42
 dtmf-relay rtp-nte
voice register pool  43
 id mac E0D1.73E4.0E7E
 type 7841
 number 1 dn 43
 dtmf-relay rtp-nte
voice register pool  44
 id mac E0D1.73E4.2AFE
 type 7841
 number 1 dn 44
 dtmf-relay rtp-nte
voice register pool  45
 id mac E0D1.73E4.2BC7
 type 7841
 number 1 dn 45
 dtmf-relay rtp-nte
voice register pool  46
 id mac E0D1.73E1.58CF
 type 8945
 number 1 dn 46
 dtmf-relay rtp-nte
voice register pool  47
 id mac E0D1.73E4.2BE2
 type 7841
 number 1 dn 47
 dtmf-relay rtp-nte
voice register pool  48
 id mac E0D1.73E4.0C93
 type 7841
 number 1 dn 48
 dtmf-relay rtp-nte
voice register pool  49
 id mac E0D1.73E4.2BC2
 type 7841
 number 1 dn 49
 dtmf-relay rtp-nte
voice register pool  50
 id mac E0D1.73E4.2B6D
 type 7841
 number 1 dn 50
 dtmf-relay rtp-nte
voice register pool  51
 id mac E0D1.73E4.2BE3
 type 7841
 number 1 dn 51
 dtmf-relay rtp-nte
voice register pool  52
 id mac 8480.2DD5.F7AD
 type 7841
 number 1 dn 52
 dtmf-relay rtp-nte
voice register pool  53
 id mac E0D1.73E4.0B35
 type 7841
 number 1 dn 53
 dtmf-relay rtp-nte
voice register pool  54
 id mac E0D1.73E4.0E88
 type 7841
 number 1 dn 54
 dtmf-relay rtp-nte
voice register pool  55
 id mac E0D1.73E1.52AB
 type 8945
 number 1 dn 55
 dtmf-relay rtp-nte
voice register pool  56
 id mac E0D1.73E4.2C48
 type 7841
 number 1 dn 56
 dtmf-relay rtp-nte
voice register pool  57
 id mac 8480.2DD5.EB1D
 type 7841
 number 1 dn 57
 dtmf-relay rtp-nte
voice register pool  58
 id mac 8480.2DD5.EA01
 type 7841
 number 1 dn 58
 dtmf-relay rtp-nte
voice register pool  59
 id mac 8480.2DD5.EB1F
 type 7841
 number 1 dn 59
 dtmf-relay rtp-nte
voice register pool  60
 id mac 8480.2DD5.EB14
 type 7841
 number 1 dn 60
 dtmf-relay rtp-nte
voice register pool  61
voice register pool  62
 id mac 8480.2DD5.EA0E
 type 7841
 number 1 dn 62
 dtmf-relay rtp-nte
voice register pool  63
 id mac 8480.2DD5.EA81
 type 7841
 number 1 dn 63
 dtmf-relay rtp-nte
voice register pool  64
 id mac 8480.2DD5.EDA6
 type 7841
 number 1 dn 64
 dtmf-relay rtp-nte
voice register pool  65
 id mac 8480.2DD5.EA6A
 type 7841
 number 1 dn 65
 dtmf-relay rtp-nte
voice register pool  66
 id mac E0D1.73E4.EB38
 type 7841
 number 1 dn 66
 dtmf-relay rtp-nte
voice register pool  67
 id mac E0D1.73E4.0C41
 type 7841
 number 1 dn 67
 dtmf-relay rtp-nte
voice register pool  68
 id mac E0D1.73E4.A5A6
 type 7861
 number 1 dn 68
 dtmf-relay rtp-nte
voice register pool  69
 id mac 8480.2DD5.E9FB
 type 7841
 number 1 dn 69
 dtmf-relay rtp-nte
voice register pool  70
 id mac E0D1.73E4.2ADD
 type 7841
 number 1 dn 70
 dtmf-relay rtp-nte
voice register pool  71
 id mac E0D1.73E4.0C63
 type 7841
 number 1 dn 71
 dtmf-relay rtp-nte
voice register pool  72
 id mac E0D1.73E1.58FB
 type 8945
 number 1 dn 72
 dtmf-relay rtp-nte
voice register pool  73
 id mac E0D1.73E4.2B00
 type 7841
 number 1 dn 73
 dtmf-relay rtp-nte
voice register pool  74
 id mac E0D1.73E4.2AF5
 type 7841
 number 1 dn 74
 dtmf-relay rtp-nte
voice register pool  75
 id mac E0D1.73E4.2B0A
 type 7841
 number 1 dn 75
 dtmf-relay rtp-nte
voice register pool  76
 id mac E0D1.73E4.2B06
 type 7841
 number 1 dn 76
 dtmf-relay rtp-nte
voice register pool  77
 id mac E0D1.73E4.2AC7
 type 7841
 number 1 dn 77
 dtmf-relay rtp-nte
voice register pool  78
 id mac E0D1.73E4.0C65
 type 7841
 number 1 dn 78
 dtmf-relay rtp-nte
voice register pool  79
 id mac E0D1.73E4.2AF9
 type 7841
 number 1 dn 79
 dtmf-relay rtp-nte
voice register pool  80
 id mac E0D1.73E4.2B1F
 type 7841
 number 1 dn 80
 dtmf-relay rtp-nte
voice register pool  81
 id mac E0D1.73E4.2AF8
 type 7841
 number 1 dn 81
 dtmf-relay rtp-nte
voice register pool  82
 id mac 8480.2DD5.E9EE
 type 7841
 number 1 dn 82
 cor incoming local-only default
 dtmf-relay rtp-nte
voice register pool  83
 id mac 8480.2DD5.EA70
 type 7841
 dtmf-relay rtp-nte
voice register pool  84
 id mac E0D1.73E1.5791
 type 8945
 number 1 dn 84
 dtmf-relay rtp-nte
voice register pool  85
 id mac 8480.2DD5.EA68
 type 7841
 number 1 dn 85
 dtmf-relay rtp-nte
voice register pool  86
 id mac 8480.2DD5.EB0C
 type 7841
 number 1 dn 86
 dtmf-relay rtp-nte
voice register pool  87
voice register pool  88
 id mac E0D1.73E4.2AFD
 number 1 dn 88
 dtmf-relay rtp-nte
voice register pool  89
 id mac 8480.2DD5.EA7E
 type 7841
 number 1 dn 89
 dtmf-relay rtp-nte
voice register pool  90
 id mac 8480.2DD5.EA93
 type 7841
 number 1 dn 90
 dtmf-relay rtp-nte
voice register pool  91
 id mac 8480.2DD5.EA95
 type 7841
 number 1 dn 91
 dtmf-relay rtp-nte
voice register pool  92
voice register pool  93
voice register pool  94
voice register pool  95
voice register pool  96
voice register pool  97
voice register pool  98
voice register pool  99
voice register pool  100
 id mac 8480.2DD5.EA2E
 type 7841
 number 1 dn 100
 dtmf-relay rtp-nte
voice register pool  101
 id mac E0D1.73E1.5809
 type 8945
 number 1 dn 101
 dtmf-relay rtp-nte
voice register pool  102
 id mac 8480.2DD5.EA6B
 type 7841
 number 1 dn 102
 dtmf-relay rtp-nte
voice register pool  103
 id mac E0D1.73E4.0C68
 type 7841
 number 1 dn 103
 dtmf-relay rtp-nte
voice register pool  104
 id mac E0D1.73E4.2AEE
 type 7841
 number 1 dn 104
 dtmf-relay rtp-nte
voice register pool  105
 id mac E0D1.73E4.2B6E
 type 7841
 number 1 dn 105
 dtmf-relay rtp-nte
voice register pool  106
 id mac E0D1.73E4.0C21
 type 7841
 number 1 dn 106
 dtmf-relay rtp-nte
voice register pool  107
 id mac E0D1.73E4.2AF7
 type 7841
 number 1 dn 107
 dtmf-relay rtp-nte
voice register pool  108
 id mac E0D1.73E4.2B05
 type 7841
 number 1 dn 108
 dtmf-relay rtp-nte
voice register pool  109
voice register pool  113
voice register pool  114
voice register pool  115
voice register pool  116
voice register pool  117
voice register pool  118
voice register pool  119
voice register pool  121
 id mac E0D1.73E4.2C4E
 type 7841
 number 1 dn 121
 dtmf-relay rtp-nte
 no vad
voice lpcor enable
voice lpcor custom
 group 10 end-users
 group 11 PSTNTrunk
voice lpcor policy end-users
 service fac
 accept end-users fac
 accept PSTNTrunk fac
voice lpcor policy PSTNTrunk
 service fac
voice translation-rule 1
 rule 1 /\(^8\)/ //
 rule 2 /\(^9\)/ //
voice translation-rule 2
 rule 1 /\(^0\)/ //
voice translation-rule 99
 rule 1 /^564\(.*\)/ /\1/
voice translation-profile DiscardDigit0
 translate called 2
voice translation-profile DiscardDigit89
 translate called 1
voice translation-profile remove564
 translate called 99
application
 package auth
  param passwd-prompt flash:enter_pin.au
  param max-retries 3
  param term-digit #
  param abort-digit *
  param passw 12345
  param user-prompt flash:enter_account.au
  param max-digits 32
license udi pid CISCO2951/K9 sn FCZ185070TS
hw-module pvdm 0/0
hw-module pvdm 0/1
username unicef privilege 15 secret 5 $1$qNgF$F2ONZovXA72J6TzHXQSaM.
username 786 password 0 54321
username 1000 password 0 12345
redundancy
controller E1 0/0/0
 framing NO-CRC4
 pri-group timeslots 1-31
controller E1 0/0/1
 framing NO-CRC4
no ip ftp passive
gw-accounting aaa
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 ip address 10.10.10.1 255.255.255.248
 duplex auto
 speed auto
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1.10
 encapsulation dot1Q 10
 ip address 10.19.51.100 255.255.255.0
 encapsulation dot1Q 20
 ip address 158.113.41.80 255.255.255.128
interface Serial0/0/0:15
 no ip address
 encapsulation ppp
 isdn incoming-voice voice
interface Serial0/0/1:15
 no ip address
 encapsulation hdlc
 no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 158.113.41.126
nls resp-timeout 1
cpd cr-id 1
tftp-server flash:rootfs78xx.10-1-1SR1-4.sbn
tftp-server flash:sboot78xx.10-1-1SR1-4.sbn
tftp-server flash:sip78xx.10-1-1SR1-4.loads
tftp-server flash:SIP894x.9-4-2SR1-2.bin1.sgn
tftp-server flash:SIP894x.9-4-2SR1-2.bin2.sgn
tftp-server flash::SIP894x.9-4-2SR1-2.bin3.sgn
tftp-server flash:SIP894x.9-4-2SR1-2.bin4.sgn
tftp-server flash:SIP894x.9-4-2SR1-2.bin5.sgn
tftp-server flash:SIP894x.9-4-2SR1-2.bin6.sgn
tftp-server flash:SIP894x.9-4-2SR1-2.bin7.sgn
tftp-server flash:SIP894x.9-4-2SR1-2.bin8.sgn
tftp-server flash:SIP894x.9-4-2SR1-2.bin9.sgn
tftp-server flash:SIP894x.9-4-2SR1-2.bin10.sgn
tftp-server flash:SIP894x.9-4-2SR1-2.bin11.sgn
tftp-server flash:SIP894x.9-4-2SR1-2.loads
tftp-server flash:SIP894x.9-4-2SR1-2.bin3.sgn
tftp-server flash:Desktops/320x212x12/CampusNight.png
tftp-server flash:Desktops/320x212x12/CiscoFountain.png
tftp-server flash:Desktops/320x212x12/MorroRock.png
tftp-server flash:Desktops/320x212x12/NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/Fountain.png
tftp-server flash:Desktops/320x212x12/CiscoLogo.png
tftp-server flash:Desktops/320x212x12/TN-CampusNight.png
tftp-server flash:Desktops/320x212x12/TN-CiscoFountain.png
tftp-server flash:Desktops/320x212x12/TN-MorroRock.png
tftp-server flash:Desktops/320x212x12/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x12/TN-Fountain.png
tftp-server flash:Desktops/320x212x12/TN-CiscoLogo.png
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:enter_pin.au
tftp-server flash:enter_account.au
tftp-server flash:cmterm-88xx-sip.10-3-1-20.k3.cop.sgn
tftp-server flash:sip78xx.10-2-1-12SR1-4.loads alias sip78xx.10-2-1-12SR1-4.loads
tftp-server flash:cmterm-7945_7965-sip.9-4-2SR1-1.cop.sgn
tftp-server flash:cmterm-7945_7965-sccp.9-4-2SR1-1.cop.sgn
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/0/1:15
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer cor custom
 name local
 name outside
dial-peer cor list local-only
 member local
dial-peer cor list local-outside
 member local
 member outside
dial-peer voice 1 pots
 corlist outgoing local-outside
 description Outgoing-calls
 translation-profile outgoing DiscardDigit0
 destination-pattern 0T
 direct-inward-dial
 port 0/0/0:15
 forward-digits all
dial-peer voice 2 pots
 paramspace callsetup after-hours-exempt TRUE
 incoming called-number .T
 port 0/0/0:15
dial-peer voice 3 voip
 description Outgoing-Calls
 translation-profile outgoing DiscardDigit89
 max-conn 4
 destination-pattern 8T
 session protocol sipv2
 session target ipv4:172.20.254.252
 dtmf-relay rtp-nte
 codec g729r8 bytes 40
 no vad
dial-peer voice 4 voip
dial-peer voice 5 voip
 destination-pattern 19..
 session target ipv4:192.168.2.2
 dtmf-relay rtp-nte
 no vad
sip-ua
 retry notify 6
 timers notify 100
 notify telephone-event max-duration 1000
gatekeeper
 shutdown
telephony-service
 no auto-reg-ephone
 max-ephones 5
 max-dn 5
 ip source-address 10.19.51.3 port 2000
 cnf-file location flash:
 max-conferences 8 gain -6
 transfer-system full-consult
ephone-dn  1
 number 1910
 label Rep BCP site 1
 name Rep BCP site 1
ephone-dn  2
 number 1911
 label Drep BCP site 2
 name Drep BCP site 2
ephone-dn  3
 number 1912
 label OPS BCP site 3
 name OPS BCP site 3
ephone  1
 mac-address 3C5E.C30C.E100
 type 7965
 button  1:1
ephone  2
 mac-address 3C5E.C30C.DE8B
 type 7965
 button  1:2
ephone  3
 mac-address 3C5E.C30C.DE60
 type 7965
 button  1:3
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password cisco
 login
 transport input telnet
scheduler allocate 20000 1000
ntp master 1
ntp update-calendar
end
Switch configuration
unicef-switch1(config-line)#do sh run
Current configuration : 8855 bytes
version 12.2
no service pad
hostname unicef-switch1
boot-start-marker
boot-end-marker
enable secret 5 $1$ROS8$mZl4Q3mLODObjtoZDrIBs1
no aaa new-model
switch 1 provision ws-c2960s-48fps-l
crypto pki trustpoint TP-self-signed-1727400320
 subject-name cn=IOS-Self-Signed-Certificate-1727400320
 rsakeypair TP-self-signed-1727400320
crypto pki certificate chain TP-self-signed-1727400320
  30820247 308201B0 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31373237 34303033 3230301E 170D3933 30333031 30303033
  31345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 37323734
  30303332 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C5B8 4C86030F D203DA90 8B0FBE44 77964617 771C87EF DAF563EB 44301DC9
  F473FD7D 24F13F03 482736DC FF301F21 9D9F1AF3 B64D21E9 77500173 596E4C91
  D212B1EB 122A0815 8B33641D 2C243028 FAF65B8A 636CBF87 8F97755B 219FECED
  272DE0C1 4D3C63D5 E01F358D F20794F4 60B2912A FDD6AB4D E873B5C6 232FE144
  2B1D0203 010001A3 6F306D30 0F060355 1D130101 FF040530 030101FF 301A0603
  551D1104 13301182 0F756E69 6365662D 73776974 6368312E 301F0603 551D2304
  18301680 1425F9EE 84A92AC6 3285C1B3 ED8E70C1 5930DA0E EC301D06 03551D0E
  04160414 25F9EE84 A92AC632 85C1B3ED 8E70C159 30DA0EEC 300D0609 2A864886
  F70D0101 04050003 81810052 AAC87963 1BAFF2B1 E5E4EB10 AF6B0DEB BC22A402
  45BD1EF1 46C2454E CD259B8A 64364D7A 53348DB7 18F50645 53C4CF18 74E3DDB3
  DD5937E2 2397B46A 9E82BB47 B20C5361 49A6314D 88BD4F3B 719A6B50 F1D1FB2E
  ABB3C560 BC496403 479C3C4B 14671D7E 5FCB6C6C EDC13C8D A3B37635 4690A762
  F418029D DE42F641 2C7A30
  quit
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
 no ip address
 shutdown
interface GigabitEthernet1/0/1
 description vers cme
 switchport mode trunk
interface GigabitEthernet1/0/2
 spanning-tree portfast
interface GigabitEthernet1/0/3
 switchport access vlan 20
 switchport mode access
 switchport voice vlan 10
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 ip address 10.19.51.7 255.255.255.0
interface Vlan20
 ip address dhcp
ip http server
line con 0
line vty 0 4
 password cisco
 login
line vty 5 15
 login
ntp clock-period 22518049
end
unicef-switch1(config-line)#do ping 10.19.51.1
Sending 5, 100-byte ICMP Echos to 10.19.51.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
unicef-switch1(config-line)#exi
unicef-switch1(config)#ip def
unicef-switch1(config)#ip default-gateway 10.19.51.1
unicef-switch1(config)#do ping 10.19.51.1
unicef-switch1(config)#do wr
[OK]
unicef-switch1(config)#do sh run
Current configuration : 8885 bytes
version 12.2
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
  quit
 no ip address
 shutdown
interface Vlan1
 no ip address
 shutdown
interface Vlan10
interface Vlan20
 ip address dhcp
ip http server
line con 0
line vty 0 4
 password cisco
 login
line vty 5 15
 login
end
You can see it also in attached.
Aristide
Chris Deren
How is the firewall fitting here for your voice environment?  Are you planning on having the firewall provide layer 3 routing for your environment?  That would not be the ideal solution for your environment, your best option would be to use the switch (assuming it's L3 switch) to perform inter vlan routing and have it's default GW point to the firewall for internet access. Is there is reason phones would need to have access to the internet across the firewall?
Hi Chris,
I can't change something about the architecture.
Aristide
