05-03-2019 11:51 PM - edited 05-04-2019 01:54 PM
Hi guys,
I'm trying to go a little bit deeper with Sip and I have a doubt on early offer and delay offer.
My question is this: what is the default offer type (early or delayed) for a phone registered on Cucm?
I know Cucm sends DO by default on Sip Trunks, but my question is regarding endpoints: will they send to Cucm EO or DO? It depends on model type or is it a configuration applied somewhere?
If this is a configuration, where do I set EO or DO for a phone?
Thanks for your comments
Cristiano
Solved! Go to Solution.
05-05-2019 07:55 AM
hi,
sip devices registered on CUCM do early offer by default. now CUCM transmit it as EO or DO, default would DO.
refer https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/trunks.html
regards
05-04-2019 02:01 PM
Anything newer than the 7940/7960 supports EO.
Also, CUCM support EO on SIP trunks. You just need to change the SIP Profile setting to Early Offer (Best Effort).
05-05-2019 07:55 AM
hi,
regards
