IP Phones go down and reboot
yasaman64
                   Hi everyone,
I am sooo new to this phone system thing but we are a small business and we hav Cisco IP phones. recently they keep having problems. sometime one of them shut downs and we have to remove the cable and plug it in back to make it come up and re-register, and sometimes some of them reboot them selves, and there was couple of times that all the phones got rebooted together and sometimes all of them go down and we have to restart the router for them to come up.
I go into every phone by typing their IP in the IE and when i go to status message i get this:
No DNS server IP
DNS unknown Host
No CTL installed
TFTP timed out
and somethings like this.
Can anyone help me with this?
20 Replies 20
Thank you so much fro your help :eonard,
here is the loggin file
Yasaman try to contact an network enginner like Paolo said.
Leonardo Santana
*** Rate All Helpful Responses***
Leonard, Can you take a lood at this line? could it be the issue?
004444: Aug  6 08:29:54.183: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/1/7 (not half duplex), with SEP0021A0858473 Port 1 (half duplex).
004445: Aug  6 08:30:54.185: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/1/7 (not half duplex), with SEP0021A0858473 Port 1 (half duplex).
This message indicates a duplex mismatch on one side of the connection:
By default, Cisco switch ports and interfaces are set to Auto-negotiate
You must match the speed and duplex settings on both sides by setting both sides to Auto-negotiate or by hardcoding.
Read this doc
http://www.cisco.com/en/US/customer/products/hw/switches/ps708/products_tech_note09186a008015bfd6.shtml
Try to contact an network enginner to help you solve this issue.
Leonardo Santana
Can I just set 0/1/7 to auto? I dont know how to access the other one and even what is that..??
i think is better you contact an network engineer to help you solve this issue.
Leonardo Santana
