08-03-2012 05:52 AM - edited 03-16-2019 12:31 PM
Hi everyone,
I am sooo new to this phone system thing but we are a small business and we hav Cisco IP phones. recently they keep having problems. sometime one of them shut downs and we have to remove the cable and plug it in back to make it come up and re-register, and sometimes some of them reboot them selves, and there was couple of times that all the phones got rebooted together and sometimes all of them go down and we have to restart the router for them to come up.
I go into every phone by typing their IP in the IE and when i go to status message i get this:
No DNS server IP
DNS unknown Host
No CTL installed
TFTP timed out
and somethings like this.
Can anyone help me with this?
08-06-2012 06:04 AM
Thank you so much fro your help :eonard,
here is the loggin file
08-06-2012 06:07 AM
Yasaman try to contact an network enginner like Paolo said.
08-06-2012 06:10 AM
Leonard, Can you take a lood at this line? could it be the issue?
004444: Aug 6 08:29:54.183: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/1/7 (not half duplex), with SEP0021A0858473 Port 1 (half duplex).
004445: Aug 6 08:30:54.185: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/1/7 (not half duplex), with SEP0021A0858473 Port 1 (half duplex).
08-06-2012 06:18 AM
This message indicates a duplex mismatch on one side of the connection:
By default, Cisco switch ports and interfaces are set to Auto-negotiate
You must match the speed and duplex settings on both sides by setting both sides to Auto-negotiate or by hardcoding.
Read this doc
Try to contact an network enginner to help you solve this issue.
08-06-2012 06:26 AM
Can I just set 0/1/7 to auto? I dont know how to access the other one and even what is that..??
08-06-2012 11:46 AM
i think is better you contact an network engineer to help you solve this issue.
