03-11-2019 10:00 AM
I have 3 cisco 8841 IP phones, These phones are showing unregistered in cucm.
I have verified these phones are coming up in switch and configured under voice vlan.
I can see three phones are receiving ip address, DHCP server is releasing the ip address . What could be the problem in this case.
解決済! 解決策の投稿を見る。
03-12-2019 01:33 PM
Troubleshoot IP Phone registration :
03-11-2019 10:04 AM
At this stage we can only think of how these Phones contacting CUCM server to register?
Do you have DHCP Options ? or how is your registration process ?
03-11-2019 10:47 AM
DHCP option is enabled and these phones are receiving different ip address when compared with other phones
03-11-2019 10:57 AM
Then check on the Switch VLAN Settings for that Access port where the Phones connected.
03-11-2019 11:20 AM
I just fixed one phone, by giving the IP address manually
03-12-2019 01:28 AM
You need to check your DHCP settings as well as to verify if the Voice Vlan is distributed through the trunk on the switch that your phones are connected.
George
03-12-2019 01:30 AM
Glad it was working, suggest to check switch side helper address (if you have multiple DHCPservers in the network) and VLAN the Phone belong to.
03-12-2019 09:13 AM
I have verified dhcp server information and the phones are receiving IP address from correct dhcp server.
Please let me know how to troubleshoot further if phone is receiving IP address.
03-12-2019 09:35 AM
What is the IP working Manually configured and tested. what is DHCP IP address you getting
can you post switch configuration to look.
03-12-2019 12:13 PM
IP Address which I manually enter is 172.27.192.51
Earlier it is receiving IP 172.27.192.15
DHCP pool information
network 172.27.192.0 255.255.255.192
interface cofnig
interface GigabitEthernet1/0/11
Switchport access vlan 10
switchport mode access
switchport voice vlan 30
no logging event link-status
srr-queue bandwidth share 10 10 60 20
queue-set 2
Priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
spanning-tree portfast edge
service-policy input AutoQos-Police-CiscoPhone
End
03-12-2019 12:52 PM
IP Address which I manually enter is 172.27.192.51 <-- is this working ?
Earlier it is receiving IP 172.27.192.15 <-- if so this should also work because same range,
Do you have any FW or access rules ?
03-12-2019 01:07 PM
172.27.192.51 yes it is working, that's what I was wondering.
is there any way to get a logs from CUCM
03-12-2019 01:33 PM
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
