IP Phones
amarmn1975
Hi Experts,
Some one can support in how can I allow IP Phones to access the internet through server  gateway to enable the rss feed services & other services as well. Noting that the voice Vlan cannot access the internet as a policy.
I had a very small application can be installed in the server to redirect the IP Phones traffic to the internet.
Appreciate your interaction.
Thanks..
Manish Gogna
Please check the following post, it should help
https://supportforums.cisco.com/discussion/12043136/xml-service-cisco-ip-phones
Manish
Thank you for your reply, but I am looking for software can allow IP Phone to access the internet while the voice vlan is not to work as  an internet gateway then I can design the xml file/
You can point phones to get the XML from the Web Server which is reachable from the Voice VLAN.
The WEb server will fetche the content and make it available to Phones via the Program code and XML.
Haris
Do you have an example please as it is not working with me,
