Ip Telephony
hello,
I'm configure cucm 8.6 with two Local DN(2200 & 1100) and one sip trunk.
when i'm calling 2200 to 1100,call is established.But when i'm calling outside through trunk,call is not established..Gives me Error is (41) Temporary failed.
Thanks...
5 Replies 5
j.huizinga
Level 6
Level 6
Do you use CUBE?
No.. I'm use only CUCM 8.6.
If you connect to a provider you might need a CUBE, don't know if it works correctly without CUBE
Bye
I'm connected my IPT Vendor by sip trunk.They give me a ipt number & all call routing.I'hv only CUCM and can manage local call.Here is my network topology...
Jaime Valencia
What's the exact call flow??
What do you use for PSTN??
java
if this helps, please rate
