ā11-26-2013 03:33 AM - edited ā03-16-2019 08:35 PM
I try to chnage the CUCM into system/cisco unified CM config into IPCCX and i recieved the below errors
I
failed to update the Cisco Unified CM Telephony user on the Cisco Unified CM.
failed to update the Cisco Unified RMuser user on the Cisco Unified CM.
I CAN change only the AXL parameters but not the CTI and the RMuser
Do you have any idea
ā11-26-2013 04:02 AM
Hi.
This belongs to the contact center section of the forum.
Anyway, do the users exist in the CUCM? Also, is your CUCM version compatible with UCCX 7.0?
G.
ā11-26-2013 04:35 AM
CUCM Version 9.x
Its working fine now but the issue is that we cant change the parameters that i wrote to the previous post
ā11-26-2013 04:43 AM
Okay, let me get this straight. So you have UCCX 7.0 integrated with CUCM 9. How did you manage to get it working?
The compatibility matrix says this combination is not supported.
G.
ā11-26-2013 05:30 AM
Yes this true
We have migrated cucms from mcs servers to ucs
Before was 7.1.5 the cucm and now in ucs is 9.x
We didnt upgrade the ccx and when we cheked its wokred perfectly
Its still working ok but we cant make any change to these parameteres
May this is the reason?
ā11-26-2013 05:59 AM
Well, yes. UCCX performs config changes over AXL, and there were a few changes in the AXL schema since CUCM 7.x.
G.
