iphone has been detected but is disabled by the administrator
Mike_fbr
I have an CP-9951 with PoE and I want to use the usb port just for charging my Iphone but as soon as I connect it apers a message in the CP-9951 "iphone has been detected but is disabled by the administrator" is there any way to enable it? I can't find the option in mi CUCM or config guides.
I don't think you will be able to charge Iphone or any other device for that matter using those USB ports. As stated in Data Sheet
"2 USB ports accelerate the usability of call handling and applications by enabling accessories such as the Cisco Unified IP Camera, wired and wireless headsets."
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-9951/data_sheet_c78-565680.html
Check below Guide as well. You will only be able to connect the Devices mentioned in the Accessories section to those USB ports
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/9971_9951_8961/10_0/english/userguide/P567_BK_UB293500_00_userguide-8961-9951-9971-10_0.pdf
Edit to the O.P No where in the documentation, it says that these ports can be used for charging purpose and therefore it is not working and will not work either.
Deepak
Deepak Rawat
Can you go to System >> Enterprise Phone configuration and check if the USB port is enabled or not. Please note parameters that you set in this window may also appear in the Common Phone Profile Configuration window and in the Phone Configuration window for various devices. If you set these same parameters in these other windows too, the following order determines the setting that takes precedence:
1) Phone Configuration window settings,
2) Common Phone Profile window settings
3) Enterprise Phone Configuration window settings.
Deepak
Hi Deepak Rawat, I have activated both usb ports options (back and side), also all usb Classes (Mass Storage, HID, Audio Class) in the Phone conf settings, Common phone profile and Enterprise Phone Config, but still recieve the message "iphone has been detected but is disabled by the administrator" :S
Deepak
I guess you are right. Thank you very much for your help and time to answer Deepak Rawat
