what radio model do you recommend to use with the IPICS? I just want to make some tests, so I don't want to buy some expensive radios. Any clue would be helpful.
Any radio that you can get a cable for will work. A good option are FRS radios that you can pick up cheap any place that sells electronics. Networkradios.com can make custom cables if they have your radio specs.
