10-05-2024 05:38 AM - last edited on 10-05-2024 06:15 PM by shazubai
I have 2 office locations. In main office I have dgm pbx server for cisco ip-phones and network range is 192.168.1.0/24. In my branch office I have network 172.16.1.0/16. I have ip-hones there. I have DMVPN tunnels between cisco router for reachibilty between 2 office.
My question is that what configurations required on branch(2nd office) so that ip-phone can register on pbx server that is located on main office.
10-05-2024 12:09 PM
It would depend on how your network works but you probably have a gateway on the office 2 somewhere if you have a different network. Somewhere on the office 2 in some layer 3 device is holding the network 172.16.1.0 for you and you should add a route on this device telling him how to reach the network 192.168.1.0 on the main office. Then, you need to do the same thing on the main office and tell the gateway how to reach the network 172.16.1.0.
10-05-2024 12:18 PM
Yes, but how IP-phone on branch office knows about pbx server ip. I have cisco router router on both offices as gateway and I added route so that both have reachibilty.
10-05-2024 12:40 PM
This is how cisco phone knows about Cisco call manager. The process to know BPX server is the same. Just keep in mind that not all cisco phone and not all firmware version is able to join Non-Cisco phone system.
https://www.ciscopress.com/articles/article.asp?p=1745631&seqNum=4
10-06-2024 02:50 AM
I understand the concept, But one thing If pbx server is on remote location I just have to specify it's address using option 150, so that ip-phone knows the pbx. Right ?
10-06-2024 03:25 AM
Cisco enterprise version phones use option 150 specified in the DHCP to connect and download configuration files. The option 150 IP address in the DHCP server is the IP address of the server hosting the TFTP service.
Since you are using a third-party PBX, are you using the MPP version of the phones ?
By the way, how did you get the phones in Location to register with the PBX?
10-06-2024 04:48 AM
Yes, I am using 6800 Series Cisco ip-phone. I am using dgm pbx. Currently the senario is that in our main office both ip-phones and pbx connected to same switch in same lan network, and phones are automatically registered to pbx server.
Can you please tell what configuration required on remote site for ip-phone to register on pbx that is located on main office. Both office has reacibilty.
10-06-2024 04:59 AM
How did the phones at the main office know how to register automatically to the PBX? They need to be instructed by something to do that as there is no way they by some act of magic would know how or even that they should do that.
10-06-2024 05:06 AM
As I told you both Digium pbx and phones are connected to same network via switch. As switch broadcast message so pbx server receive request, I think that is one reason no configuration required to tell these phone about pbx server as they receive request via switch.
