Is it posible to ring different ringtones for different calls?
mello_mello
Hello.
Is it possible for Cisco IP phones (7960) to configure different ringtones for different calls? i mean if the boss is calling - one ringtone, if other people - differens ringtone?
Thanks in advance.
Rob Huffman
Hi Mello,
This is NOT possible based on the CLID of the caller
This is the closest thing;
Distinctive Ring per Line
This release adds support for seven distinctive ring patterns to Cisco IP phones. Phone users with multiline phones can configure a distinctive ring pattern for each line on the basis of a logical precedence or importance.
This setting is done on the phone itself. Via Settings>User Preferences>Rings
Once there you can select the Line that you want to set a ring for and Select>Play>Select>Save>Exit
Hope this helps!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Rob Huffman
Hi Mello,
Hope this helps!
Rob
David Hailey
No.  You can only configure different ringtones (available on the system) on a per-line basis.  So lines have distinctive rings but not calls.
mello_mello
Thank you!
I thought as much...
saccotexas
Hi, is it possible to change the ring patterns on a Cisco 8841 ?  example: I would like it to ring 3 time at the front desk phone, then ring all the phones after 3 rings.
