Is it possible to block all outgoing calls on a multiple buttons Cisco Phone and allow only speed dials?
mystergag
I want to know if it is possible to block the possibility to make outgoing calls and allow only calls to pre-programed specific numbers (speed dial or else)?
exemple:   Program the two buttons of 7941 to specific numbers and allow only those to be called. No possibility to make other call whatsoever with that phone.
Rob Huffman
Hi Gabriel,
You could program both keys on the 7941 to use "Hotdials" and
they would only ring the two pre-programmed numbers
The step by step directions in this guide are very good
Hotdial on IP Phones with CallManager Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080232b9f.shtml
Cheers!
Rob
"Spend your life waiting,
for a moment that just don't come,
Well, don't waste your time waiting"
-Springsteen
