Unity Connection Call Handler Rings
Phil Bradley
Level 4
Level 4
Hello All. Is there a way to add rings before a system call handler picks up in unity connection? We are running version 8.6 and when a caller dials the call handler extension it immediately starts playing the greeting without the caller hearing rings.
Thanks!
Rob Huffman
Hey Phil,
Well I'm stumped (no surprise )
But I did come up with a work around if you
are interested. I am attaching a ringback.wav
file that I used on a front end call handler greeting
(using reprompt caller = 3 time between reprompts = 2)
I then used the after greeting action to route to the required
call handler.
So I called 8567 which is now call handler #1 it plays the 4 rings
and then transfers (directly to greeting) to the actual informational
call handler @ 6198 using the after greeting action on 8567.
Cheers!
Rob
"Spend your life waiting,
for a moment that just don't come,
Well, don't waste your time waiting"
-Springsteen
15 Replies 15
Rob Huffman
Hi Phil,
I've done this in the past using a CTI -RP in CUCM with the
Call Handler extension/DN and leveraging the Forward No Answer
rather than using Forward All (on the CTI-RP DN config page)
Cheers!
Rob
-Springsteen
Thanks for the response Rob. For some reason the CTI-RP is not registering with unity connection. I notice that I have to have Forward Unregistered Internal/External checked for unity to pick the call up. It just rings busy if I have forward no answer by itself checked. I assume the no answer ring duration only applies to the forward no answer.
Rob Huffman
Hi Phil,
You won't see the CTI-RP's as registered so that part is cool. I would check
the CSS(s) for the forwarding anomolies. You should be able to use Forward all
and Forward No Answer without issue.
Cheers!
Rob
-Springsteen
Ok, for some reason the forward no answer just gives a busy. I checked the CSS for the No Answer and it is using the same one that my other DN's and Forward Unregistered are using. The only way I can get it to route to unity is with the Forward unregistered checkboxes checked.
Hi Phil,
When you get a window, can you try deleting the CTI-RP
and deleting the DN from the Unassigned DN's via the Route Plan
Report page and then rebuilding the CTI-RP. Make sure to pay special
attention to the Partition/CSS and then retest.
I have looked for any bugs related to this type of issue and have
come up empty. Are both Connection and CUCM @ 8.6?
Cheers!
Rob
-Springsteen
I will give that a try and see what happens.
Yes, both CUCM and UC are 8.6. This is the Business Edition so both are on the same server.
I just did delete the CTI-RP and unassigned DN but still have the same issue. As soon as I check Forward Unregistered the route point will go to the call handler and greeting.
Rob Huffman
Hi Phil,
Maybe the CTI-RP works differently in Business Edition?? I
can't vefiry this as we don't run it
In BE can you go to Call Routing> Directory Number and create the DN
directly? It's another method to route calls where you might be able to
use the forward no answer. Or create a "dummy" phone with the DN
and use the forward no answer.
Just trying to think of different options.
Cheers!
Rob
-Springsteen
Hello Rob,
I believe the only difference between BE and CM is that I cannot have a subscriber with BE edition. Other than that the software I believe is the same.
I did orginially create the DN like you mentioned above and it still requires the Forward Unregistered to be checked. Also, I tried to create the "dummy phone" and it just rings busy too.
Thanks for all of the suggestions.
Rob Huffman
Hi Phil,
Something doesn't add up here at all. These are all valid
ways to route calls via forward no answer forward all etc.
It's got to be a CSS/Partition issue I far as I can tell. I'm stumped
other than that my friend
Does your phone Forward No Answer to voicemail work? If so, can
you try with the exact same CSS/Partition set on the CTI-RP forward
settings.
Cheers!
Rob
-Springsteen
Hello Rob,
Yes, my phone does work with forward no answer and is in the same partition/CSS as the CTI-RP and DN that I created. The only thing that I notice is that the status of the route point is unknown which I believe you said is normal. However, since the DN/CTI-RP is not registered to anything would this maybe force the DN to use Forward Unregistered and bypass the Forward No Answer? I would also assume since the call handler picks up when I have the Forward Unregistered checked that the CSS/Partition must be correct. This is the same one that I am using on the no answer option.
Thanks!
Rob Huffman
Hey Phil,
call handler.
Cheers!
Rob
-Springsteen
Maybe this is a bug and not that you are stumped :).
I like your concept of adding the ring wave file to a call handler and then passing it on to the message call handler. I will give this a try and report back.
Awesome idea!
Phil
I just tested this and it does exactly as you said. Thanks for your workaround and time!
I may open up a TAC case to see if they can look into this and will post back if they come up with anything.
Thanks again,
Phil
