Is it possible to configure SRST with two Branch router
Mukesh Singh
                   Hi Team,
Is it possible to configure SRST with two Branch router so that branch phones can register 50-50 for load balancing.if this is possible,what are the configration steps.
Mukesh
Jaime Valencia
There's nothing special to this, just configure SRST on the routers, and configure two SRST references in CUCM to distribute the charge as you need. That's it.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Nadeem Ahmed
In this case you can create two device pool and SRST reference of two branch router .. Assign Half of the Phones with one device pool and half with other..this will help you to achieve your requirement
Br,
Nadeem
Br, Nadeem Please rate all useful post.
