Is it possible to connect 2 ATAs 192 together?
Ahmed Wasim
Hi All,
We have only 1 port available and we need to connect 4 analog phones.
Is it possible to connect the network port of the ATA192 to this available port and then connect its ethernet port to another ATA? If yes, will there be any required configuration on the ATAs?
Hi, yes it's possible.
Set the ATA 192 to operate in bridge mode.
"Bridge: Bridged mode is used if the ATA is acting as a bridge device to another router. Choose this option if your ATA bridges a network to its LAN port (with connected devices also in the 10.0.0x range)."
See the link below and search for Router_Mode Bridge
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cata/19x/3PCC/english/provguide/at1x_b_ata191-ata192-mpp-prov/at1x_b_ata191-ata192-mpp-prov_chapter_0110.html
Regards.
