Is it possible to display the name of an incoming number on cucm?
carl_townshend
Hi All
for example if I call in from an external number, can I put this on a phonebook or directory so the internal cucm phone will display a name ?
cheers
Chris Deren
No, there is no external lookup for calling name, it will show whatever the telco provider passes to you.
Alternatively you could look into CURRI integration, but I dont know if that would allow for it, and how scalable this would be.
Jaime Valencia
You would need 3rd party apps for that, CUCM doesn't provide that feature natively.
java
if this helps, please rate
