is it possible to send a Inbound call right back out the gateway
Bhunt 410
I have a customer who wants to send a inbound call to a 800 number once its dialed.  I was going to do a CTI route point and point it back out, but I'm looking for some other options.  Does anyone know if I can send it right back out from a 2811 router?
Correct,  you would create a new inbound pots dial-peer, assuming the gateway is VoIP-TDM, then create a translation rule to modify the called number. There should be no need to configure an outbound dial-peer as long as the translated called number matches the existing one.
For example,
Called number: 8000
New Called number: 18005532447
voice translation-rule 1
rule 1 /^8000/ /918005532447/
voice translation-profile fwd1800
translate called 1
new inbound dial-peer
dial-peer voice 1000 pots
translation-profile inbound fwd1800
incoming called-number 8000
port x/y
This example assumes that all outbound calls are prefixed with a 9 and that the outbound dial-peer matches on the 9 and strips it being sending the call to the PSTN. I also assume that the gateway is H.323/SIP.
If MGCP, this would need to be done on CUCM using translation patterns and CSS/PT changes.
-Felipe
6 Replies 6
Clifford McGlamry
Yes, it can be done.
If you do this, the call will consume 2 trunks for the duration of the call.  Plan your resources accordingly.
how would I go about doing that?  Would it just be a dial-peer to catch the number and a voice translation of some sort to send it back out?
You would need two dial-peers: Your normal incoming dial-peer and a second outgoing dial-peer also on the PSTN circuit. Translations are up to you but at a minimum be sure that the outbound dial-peer sends the correct digits to the PSTN or the outbound call leg will fail.
For example,
Called number: 8000
translate called 1
port x/y
-Felipe
An alternative (and simpler) approach would be to use number expansion.
Taking the numbers from Felipe's example and assuming that you have an existing outbound dial peer all you need to do is enter the command below in global config mode.
num-exp 8000 918005532447
This should work for H.323 and SIP gateways.
Thanks so much for your help.  You guys are awesome!!!!!!!!!!!
