Is shared Line not supported for Third-Party AS-SIP Device ?
stanislav23
When we try to add shared line for Third-Party AS-SIP Device and Cisco IP Phone we received the message "Update failed. Shared Line feature is not supported".
I can not find anywhere in configuration guides that shared line in not supported with this device type.
Stanislav
Jaime Valencia
It is indeed not supported as the message you received states.
java
if this helps, please rate
George Sotiropoulos
Hellos,
Unfortunately, this is not supported. I have recently faced the same issue but the message you receive is clear.
George
Hope the above helps,
gsotirop
