CUBE not register SIP Trunk
jobyeonghun
Hi  All
I am installing CUBE
However, CUBE is not registered with sip-trunk.telekom.de.
Please check the configuration and debug messages.
sip
bind control source-interface GigabitEthernet0/0/0
bind media source-interface GigabitEthernet0/0/0
rel1xx disable
session refresh
asserted-id pai
outbound-proxy dns:reg.sip-trunk.telekom.de
conn-reuse
no update-callerid
privacy-policy passthru
sip-profiles 3000
voice class sip-profiles 3000
rule 1 request REGISTER sip-header Contact modify "<.*:.*@(.*)>" "<sip:\1;bnc>"
rule 2 request REGISTER sip-header Require add "Require: gin"
sip-ua
credentials number +********* username ********* password 7 ********* realm sip-trunk.telekom.de
authentication username ********* password 7 ********* realm sip-trunk.telekom.de
no remote-party-id
timers dns registrar-cache ttl
registrar dns:sip-trunk.telekom.de expires 240 tcp auth-realm sip-trunk.telekom.de
sip-server dns:sip-trunk.telekom.de
connection-reuse
host-registrar
debug message
Nov 10 12:34:59.214: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x7F35BDBB9F50) with key=[61] to table
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/verbose/4097/ccsip_platform_init_ccb: Initialising rtp session queue
Nov 10 12:34:59.214: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sipSPISetSipProfilesTag: voice class SIP Profiles tag is set : 3000
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/notify/262144/ccsipRegisterSetTargetInfo: p2p mode with Registrar Server = dns:sip-trunk.telekom.de
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/verbose/262144/ccsipRegisterSetTargetInfo: Parsing The Registrar Address
Nov 10 12:34:59.214: //-1/xxxxxxxxxxxx/SIP/Info/verbose/5120/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : sip-trunk.telekom.de target_port : 5060
Nov 10 12:34:59.214: //-1/xxxxxxxxxxxx/SIP/Info/verbose/5120/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: outbound_host : reg.sip-trunk.telekom.de outbound_port : 5060
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/critical/8192/sipSPIOutboundProxyReuse: Do not reuse Outbound Proxy IP adress and Port
Nov 10 12:34:59.214: //-1/000000000000/SIP/State/sipSPIChangeState: 0x7F35BDBB9F50 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/verbose/6144/ccsip_spi_registrar_add_expires_header: Inside ccsip_spi_registrar_add_expires_header for Expires
Nov 10 12:34:59.215: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 10 12:34:59.215: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/sipSPIIncrementOverloadCount: Local 1 Global 1
Nov 10 12:34:59.215: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 40
Nov 10 12:34:59.215: //-1/000000000000/SIP/Info/verbose/262144/act_idle_outgoing_register: In act_idle_outgoing_register
Nov 10 12:34:59.215: //56/000000000000/SIP/Info/info/262144/act_idle_outgoing_register: Send REGISTER to reg.sip-trunk.telekom.de:5060
Nov 10 12:34:59.215: //56/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToUACTable: ****Adding to UAC table.0x7F35BDBB9F50 FFFFFFFF8FFB8890-FFFFFFFFE41611E8-FFFFFFFF8007DFFB-31CC279D
Nov 10 12:34:59.215: //56/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x7F35BDBB9F50 key=FFFFFFFF8FFB8890-FFFFFFFFE41611E8-FFFFFFFF8007DFFB-31CC279D balance 1
Nov 10 12:34:59.215: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 10 12:34:59.215: //56/000000000000/SIP/State/sipSPIChangeState: 0x7F35BDBB9F50 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_SENT_DNS)
Nov 10 12:34:59.215: //56/000000000000/SIP/State/sipSPIChangeState: 0x7F35BDBB9F50 : State change from (STATE_IDLE, SUBSTATE_SENT_DNS) to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_SENT_DNS)
Nov 10 12:34:59.215: //-1/xxxxxxxxxxxx/SIP/Info/notify/8192/sip_dns_type_srv_query: TYPE SRV query for _sip._tcp.reg.sip-trunk.telekom.de and type:1
Nov 10 12:34:59.218: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/sip_dns_type_a_aaaa_query: DNS query for reg.sip-trunk.telekom.de and type:1
Nov 10 12:34:59.220: //-1/xxxxxxxxxxxx/SIP/Error/sip_dns_type_a_query:
TYPE A query failed for reg.sip-trunk.telekom.de
Nov 10 12:34:59.220: //-1/xxxxxxxxxxxx/SIP/Error/_send_dns_fail:
DNS Query for reg.sip-trunk.telekom.de failed
Nov 10 12:34:59.220: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 43
Nov 10 12:34:59.221: //56/000000000000/SIP/Error/act_register_dns_resolved:
DNS Query failed for query_type:1
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_api_register_target_dns_resolved: ttl = -1
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/sipSPIDecrementOverloadCount: Count:Local 0 Global 0
Nov 10 12:34:59.221: //56/000000000000/SIP/Error/ccsip_api_register_result_ind:
Message Code Class 4xx Method Code 100 received for REGISTER
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_register_reset_dns_cache: CCSIP_REGISTER:: registrar 0 DNS resolved addr reset
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/notify/262144/sipSPIRegPthruProcessResponse: Processing response w/ resp code == 503
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/verbose/262144/sipSPIGetRPCBFromRCB: Retreiving RCB [0x7F35BE1202F8] from RPCB [0x0]
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/critical/262144/sipSPIRegPthruProcessResponse: Error NO RPCB
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/ccsipRegisterStartRCBTimer: Starting timer for pattern +49697912790 for 120 seconds
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[61] removed.
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x7F35BDBB9F50 key=FFFFFFFF8FFB8890-FFFFFFFFE41611E8-FFFFFFFF8007DFFB-31CC279D
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Nov 10 12:34:59.221: //56/000000000000/SIP/Error/sipSPIFlushDeferredQueue:
Invalid deferredQueue
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x7F35BDBB9F50
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIGetContextFromTable: NO context for key[61]
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
please help me
6 Replies 6
Dennis Mink
can you post a debug ccsip message so we can see if you are getting authorized by your provider at all?
cheers
Please remember to rate useful posts, by clicking on the stars below.
The debug message above is a debug ccsip all message.
but show sip-ua register status
The state of regi is no.
please help
Gunnar Reiser
Level 4
Level 4
reason is in the debug: "DNS Query for reg.sip-trunk.telekom.de failed".
CUBE has no working DNS hence it can't identify where (which IP) to connect to.
Check DNS on CUBE, once that is working it will get you a step further.
Cheers,
Gunnar
Its failing because the DNS is failing to resolve reg.sip-trunk.telekom.de
which is used as your outbound proxy.
- do you need outbound proxy or registrar server is only required
vayacontioz
Hello jobyeonghun,
I have the same problem. How did you solve it?
I am having the same issue registering the SIP from DTAG with CUBE.  Did you manage to fix it?
