07-10-2013 12:52 PM - edited 03-16-2019 06:18 PM
I have a few questions about resolving ip phone's hostname to ip address.
- Is there any possible way other than polling device info from call manager (with RisPort Soap service) to retrieve phone's ip address?
- Can we get this information directly from phone?
- Is it possible to program ip phone so that it registers or subscribes itself to a CTI application and inform the app from its status and IP address changes?
Thanks for sharing you experience in advance,
Parisa
07-10-2013 02:50 PM
The easiest method is going to be via SNMP through CallManager. This is how CER gets phone IP addresses. Just create a Read-only SNMPv2 Community string in CUCM.
07-11-2013 08:19 AM
Hi Brian,
Thanks for your reply. Can you please explain a little bit or share some links in this regard?
Parisa
07-11-2013 09:01 AM
Parisa,
Take a look at the ccmPhoneEntry object.
It has an entry for ccmPhoneInetAddressIPv4 that you can use.
You just need to create a tool to pull these OIDs from CallManager to get the device information.
Brian
