Is there a way other than using RisPort Soap Services To retrive phone ip adress?
I have a few questions about resolving ip phone's hostname to ip address.
- Is there any possible way other than polling device info from call manager (with RisPort Soap service) to retrieve phone's ip address?
- Can we get this information directly from phone?
- Is it possible to program ip phone so that it registers or subscribes itself to a CTI application and inform the app from its status and IP address changes?
Thanks for sharing you experience in advance,
Parisa
brmeade
Level 4
Level 4
The easiest method is going to be via SNMP through CallManager.  This is how CER gets phone IP addresses.  Just create a Read-only SNMPv2 Community string in CUCM.
Hi Brian,
Thanks for your reply. Can you please explain a little bit or share some links in this regard?
Parisa
Parisa,
Take a look at the ccmPhoneEntry object.
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=ccmPhoneEntry#oidContent
It has an entry for ccmPhoneInetAddressIPv4 that you can use.
You just need to create a tool to pull these OIDs from CallManager to get the device information.
Brian
