ISDN E1 - 2801 - 64 DSP - %Insufficient resources to create pri-group
nwkotze
OVR-LAN-V-GW1#sho inv
NAME: "chassis", DESCR: "2801 chassis"
PID: CISCO2801 , VID: VN/A, SN:
NAME: "VIC 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN:
NAME: "PVDM 0", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN:
S2S-OVR-LAN-V-GW1#
card type e1 0 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-net5
controller E1 0/0/0
framing NO-CRC4
S2S-OVR-LAN-V-GW1(config-controller)#pri-group timeslots 1-31
% Not all config may be removed and may reappear after reactivating the logical-interface/sub-interfaces
%Insufficient resources to create pri-group - it has been removed
S2S-OVR-LAN-V-GW1#sho flash
-#- --length-- -----date/time------ path
1 27352008 Jul 10 2009 17:39:42 +01:00 c2801-spservicesk9-mz.124-25a.bin
36532224 bytes available (27353088 bytes used)
sho ver:
System image file is "flash:c2801-spservicesk9-mz.124-25a.bin"
Cisco 2801 (revision 5.0) with 352256K/40960K bytes of memory.
Processor board ID FHK084711TB
2 FastEthernet interfaces
2 Channelized E1/PRI ports
4 DSPs, 64 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62592K bytes of ATA CompactFlash
The suggestion was not to move the DSP module to slot 1, it was to move the VWIC card to another slot. If you still need convincing, this URL explicitly states the limitation on slot 0 -
http://www.cisco.com/en/US/docs/routers/access/2800/hardware/installation/guide/01_hw.html#wp1089015
Under Figure 7, it states the following -
Note Slot 0 does not support PRI on T1/E1 VWICs, only channel-associated signaling (CAS) digital voice.
20 Replies 20
paolo bevilacqua
Should not happed, can you try a different IOS ?
Cisco IOS Software, 2801 Software (C2801-ADVIPSERVICESK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Same, do not work...
karldbrooks
Level 4
Level 4
- Have you got any H/W conference or transcoding configured on the same gateway? If not try upgrading the IOS to a T train release on a ipvoice feature set.
S2S-OVR-LAN-V-GW1#dir
Directory of flash:/
1 -rw- 47246564 Jul 13 2009 13:54:30 +01:00 c2801-advipservicesk9-mz.124-22.T.bin
63864832 bytes total (16617472 bytes free)
S2S-OVR-LAN-V-GW1#
Still not working...
The E1 will not work in Slot 0 of a 2801, put it in Slot 1.
S2S-OVR-LAN-V-GW1(config)#card type e1 ?
<0-0> Card slot number (always 0 for 1800 series & 2801 routers)
S2S-OVR-LAN-V-GW1(config)#network-clock-participate wic 1
WIC slot is empty or does not support clock participate
S2S-OVR-LAN-V-GW1(config)#network-clock-participate wic 0
S2S-OVR-LAN-V-GW1(config)#network-clock-participate wic 2
S2S-OVR-LAN-V-GW1(config)#network-clock-participate wic 3
S2S-OVR-LAN-V-GW1(config)#network-clock-participate wic 4
Slot 1 do not support Voice Cards!!!!!
E1 is only supported on Slot 0:
Slot 0 does not support this card, even Cisco is shipping it in this position.
Try it. Really. Power down the router, move the card from Slot 0 to Slot 1 or 2. Power up the router. In CLI you will be able to configure it with card type in position 1 or 2. As long as you have not moved the card physically tp Slot 1 or 2 it will always show you Slot 0 as only option.
I had this issue several times, Slot 0 in a 2801 is a special Slot with reduced capabilities.
See also here:
http://www.ciscotaccc.com/voice/showcase?case=K19287315
As this was the solution to your problem (moving the E1 to another slot than slot 0), i do not understand why my posting was rated with 1.
No Conference or transcoding Profiles configured this is a brand new config I strted. I eraced the old config.
I'm trying the Latest on the T train now...
If you have no joy there try seating the PVDM in another slot.
Moved the PVDM to slot 1, did not work...
NAME: "PVDM 1", DESCR: "PVDMII DSP SIMM with four DSPs"
S2S-OVR-LAN-V-GW1(config-controller)#pri-group timeslots 1 - 31
S2S-OVR-LAN-V_STARTSTOP: Logging to host 10.0.10.128 port 514 started - CLI initiated
*Jul 13 16:10:28.031: %DSPRM-5-UPDOWN: DSP 8 in slot 0, changed state to up-GW1>
*Jul 13 16:10:29.575: %DSPRM-5-UPDOWN: DSP 7 in slot 0, changed state to up
*Jul 13 16:10:31.119: %DSPRM-5-UPDOWN: DSP 6 in slot 0, changed state to up
*Jul 13 16:10:32.663: %DSPRM-5-UPDOWN: DSP 5 in slot 0, changed state to up
S2S-OVR-LAN-V-GW1>
