ISDN point-to-multipoint
davidsr
Hi, we have a VIC2-2BRI-NT/TE and the layer 1 is deactivated. The ISDN line is a point-to-multipoint , and the carrier has test the line and all is correct (include the cable that arrive to the card). The IOS is 12.4.(4)XC4 (before upgrade we use IOS 12.4.(4)XC ) , and we use two different cards (VIC2-2BRI-NT/TE), that in another installatio work propertly..The BRI config is :
interface BRI2/0
no ip address
isdn switch-type basic-net3
isdn incoming-voice voice
isdn static tei 0
FYI , when a outbound call arrive the layer 1 is actived , and then during 4 minutes aprox. we can raise a calls. Any idea ? Is very strange problemm..
Many thanks
paolo bevilacqua
first of all, point-to-multipoint BRI usually do not uses static tei, instead tei assigned by the switch. For static tes, you may also need isdn point-to-point setup command.
second, it is normal that layer 1 goes inactive. The matter is that the router must be able to reactivate L1 it when placing a call.
Please post debug ISDN Q.931 and normal ISDN logs from the router.
paolo bevilacqua
