ISDN Setup message
chevymannie
UCM version 7.1.3.10000-11
2811 configured as an H.323 gateway running 12.4(13r)T.
I have one user that is having difficulty dialing numbers.  This happens at random and he is the only one that has reported the issue.  The symptoms are he dials a long distance number and receives a fast busy signal.  The call reaches the gateway, but the isdn setup message is as follows:
        Bearer Capability i = 0x8890
                Standard = CCITT
                Transfer Capability = Unrestricted Digital
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Calling Party Number i = 0x2181, 'XXXXXXXXXX'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '1XXXXXXXXXX'
022620: Feb 22 15:58:10.098: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x913E
022621: Feb 22 15:58:12.379: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x913E
        Cause i = 0x8091 - User busy
All my other calls show something different under transfer capability, but I've noticed whenever his call fails the message is identical to the above.
Just to note:  I have verified that his phone is configured with the correct CSS and that his DN is in the correct partiton.
phooghen
Are you sure you are not trying to make a video call (CUVA ...) across PSTN ?
Maybe you can try to issue the bearer-cap speech command under the voice port to avoid making video calls.
Pierre
phooghen
Pierre
Pierre,
That's a good idea.  He does have CUVA, but I didn't think about that.  Does this command have any other impact that I need to be aware of?
It will only disable video calls across PSTN. Not other impact.
