ISDN test call while registered to CUCM
blamerson
Hello.  I'm trying to a PRI while it is also registered to CUCM (long story as to the need for this).  I assumed this would not be a problem, but I cannot get it to work, so can someone clarify?  I can neither use csim start nor isdn test call effectively.  Here's my config:
interface Serial0/1/1:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
end
dial-peer voice 8888 pots
destination-pattern 9T
port 0/1/1:23
csim start gives the following (number substituted):
csim start 95555555
csim: called number = 95555555, loop count = 1 ping count = 0
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
debug voip dialpeer all shows it selecting dial-peer 8888
isdn test call and debug isdn q931 gives the following:
isdn test call int s0/1/1:23 5555555555
Jul  9 09:07:33.119: ISDN Se0/1/1:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Called num 2092305335
Jul  9 09:07:33.119: ISDN Se0/1/1:23 Q931: TX -> SETUP pd = 8  callref = 0x0084
        Bearer Capability i = 0x8890
                Standard = CCITT
                Transfer Capability = Unrestricted Digital
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Called Party Number i = 0xA1, '5555555555'
                Plan:ISDN, Type:National
Jul  9 09:07:33.439: ISDN Se0/1/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8084
DPOL-3845-VG#
Jul  9 09:07:33.443: ISDN Se0/1/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0084
        Cause i = 0x80D1 - Invalid call reference value
Any help would be appreciated!!
Brian
Joseph Martini
I don't think you can use csim start to testing when you are back haul layer 3 to CUCM.  The problem comes in when the reply comes in for a SETUP CUCM didn't originate therefore it doesn't accept it.  The router won't intercept the q931 on 0/1/1:23 since you have isdn bind-l3 ccm.
7 Replies 7
Jaime Valencia
If you're telling it to bind L3 info to CUCM then why don't you just create a RP, bind the GW/int and place a call from there??
That test call shows as unrestricted digital, that's a video call.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
I mentioned it being a long story..  =) - this is the synopsis..
The router currently is registered to CUCM.  The company is moving to a new location, but wants to verify the PRI as operational before they move.  So, they're going to take one of their existing routers which is registered to CUCM to the site and have a softphone or handset register to the router and test the PRI.  I was trying to verify at the very least that I could make calls on the PRI now with csim start or isdn test call.  So, the CUCM won't be on-site during this testing phase.
Joseph Martini
Ayodeji Okanlawon
Brian,
Apart from the excellent info provided by Jo, you might want to modify the bearer cap on the gateway as well.
Try this..
voice-port 0/1/1:23
bearer-cap Speech
The bearer cap you are using as mentioned by Java is
0x8890Unrestricted digital information64 Kbps (64k data call)
As you can see this is for a data call. Your gateway is disconnecting the call.
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
I've applied the bearer-cap speed to the voice port as well as "no isdn bind-l3 ccm" on s0/1/1:23 just to test:
Jul  9 10:23:25.881: ISDN Se0/1/1:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Called num 55555555555
Jul  9 10:23:25.881: ISDN Se0/1/1:23 Q931: TX -> SETUP pd = 8  callref = 0x0096
                Standard = CCITT
Jul  9 10:23:26.157: ISDN Se0/1/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8096
Jul  9 10:23:26.157: ISDN Se0/1/1:23 **ERROR**: call_setup_ack_proceeding: NO HDLC available b channel 22 call id 0x8017
Jul  9 10:23:26.157: ISDN Se0/1/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0096
        Cause i = 0x80A2 - No circuit/channel available
Jul 9 10:23:26.221: ISDN Se0/1/1:23 Q931: RX <- RELEASE pd = 8 callref = 0x8096
Cause i = 0x82A2 - No circuit/channel available
Jul 9 10:23:26.221: ISDN Se0/1/1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x0096
These are full PRIs and channel 22 is available.  Just to verify, I changed the b channel order to ascending, and it said that channel 1 was also "NO HDLC available".  Thanks for the help so far though!
Two things..
1. The bearer-cap is speech not speed. I hope thats what you have.
2. Your capability is still showing as unretsricted digital
3. Your router is disconnecting the call....
4. What type of hardware do you have..can you do a "sh diag"
5. Can you do the ff shows:
show voice dsp detail
show voice dsp voice
6. Use the ff procedure to test the status of your dsps..
*****VG#test voice driver*******
Enter VPM or HDV or ATM AIM or NM-HD-xx or HDV2 slot number : 0
C2800 Debugging Section;
1 - FPGA Registers Read/Write
2 - 5510 DSP test
3 - DSPRM test
4 - HDLC32 test
5 - Quit
*******Select option : 2********
5510 DSP Testing Section:
1 - Reset ALL DSPs
2 - Reset 1 DSP
3 - Download DSPware
4 - CHPIR Enable/Disable
5 - Display c5510 ring
6 - Show HPI RAM
7 - Show eHPI memory thru Relay command
8 - Show Controller
9 - c5510 Keepalive Enable/Disable
10 - Download bootloader using indirect slave access
11 - Write HPI RAM
13 - DSP application download
14 - faked dsp crash
15 - Wait in Firmware Restart Indication
16 - Display DSP Keepalive Status
17 - QUIT
******Select option : 16*********
DSP Keepalive Status Display:
DSP 1 is Alive, State: 4, Keepalive Sent: 327216, Skip 566572
DSP 2 is not UP, State: 5, Keepalive Sent: 0, Skip 0
DSP 3 is Alive, State: 4, Keepalive Sent: 417410, Skip 476382
Hi aokanlawon.  Thanks for following up!  I think at this point it's just not worth the amount of time it will take in order to generate this test environment.  I appreciate yours and everyones help though.
