12-18-2012 05:09 AM - edited 03-16-2019 02:46 PM
I have a cme with ism cue installed,everytime i session to my ism0/0, it seems as if i am in stuck in user mode, i can't go in offline mode nor change anything in the configuration of the ism, i cant go in the enable mode.
the web pager of the gui opens up but can't login also, i keep getting:
System is not initialized. Only Administrator logins are allowed.
12-18-2012 05:46 AM
Log in with CLI and complete wizard.
12-18-2012 06:03 AM
the thing is when i loging with cli , im not getting any wizard to complete.
12-18-2012 06:18 AM
In CLI check administrator credentials, login in GUI with that, you will presented the wizard.
12-18-2012 06:51 AM
ou
as you can see in the above picture im not having any exec command to do the wizard or any config...
12-18-2012 07:02 AM
You can re-install CUE software, or check what happens at boot (service module reset).
Note: when working with CLI devices, use text copy and paste, not screenshots.
12-18-2012 07:28 AM
Paolo 1st thx for your help,
at the reset i get the following :
192.168.200.10#service-module isM 0/0 reset
Use reset only to recover from shutdown or failed state
Warning: May lose data on the the NVRAM, nonvolatile file system or unsaved configuration!
Do you want to reset?[confirm]
Trying to reload Service Module ISM0/0.
192.168.200.10#ser
192.168.200.10#service-module isM 0/0 ses
192.168.200.10#service-module isM 0/0 session
Trying 192.168.200.10, 2131 ... Open
DDR Memory 0512 MB detected
Genuine Intel(R) processor 1.06GHz
BIOS ISM 2.6, BIOS Build date: 10/16/2009
System now booting...
Authenticating boot loader....
Secondary Boot Loader authenticated - booting....
Please enter '***' to change boot configuration:
Detect and Initialize network device
Backup current platform configurations....
SRE step 1 - SM registration...
Finding (hd0,3)/296e03bc-3236-4a68-a178-688e56400a1e, failed
Local install not supported
Response - no installation needed (len: 422)
SRE Installation Not Needed
Restoring orignial configuration...
Updating flash with bootloader configuration.
Please wait .................. done.
Loading disk:/bzImage ... Verifying ... done.
Starting Kernel.
Platform: ism
sd 0:0:0:0: [sda] Assuming drive cache: write through
Verifying application level programs
Application level programs verification OK!
INIT: version 2.86 booting
mounting proc fs ...
mounting sys fs ...
mounting /dev/shm tmpfs ...
reiser root fs ...
Reiserfs super block in block 16 on 0x801 of format 3.6 with standard journal
Blocks (total/free): 1002928/905703 by 4096 bytes
Filesystem is NOT clean
Filesystem seems mounted read-only. Skipping journal replay.
Checking internal tree..finished
FILESYSTEM CLEAN
Remounting the root filesystem read-write...
kernel.sem = 1900 4000 32 100
vm.overcommit_memory = 1
vm.min_free_kbytes = 8192
Welcome to Cisco Service Engine
Setting the system time from hardware clock
********** rc.aesop ****************
Populating resource values from /etc/ism_rsrc_file
Populating resource values from /etc/default_rsrc_file
Populating resource values from /etc/products/cue/default_rsrc_file
Populating resource values from /etc/products/cue/ism_rsrc_file
Processing manifests . . . . . . . . . . . . complete
==> Management interface is eth0
Serial Number: FOC16383CYB
INIT: Entering runlevel: 2
********** rc.post_install ****************
INIT: Switching to runlevel: 4
INIT: Sending processes the TERM signal
==> Starting CDP
STARTED: ntp_startup.sh
STARTED: LDAP_startup.sh
STARTED: SQL_startup.sh
STARTED: dwnldr_startup.sh
STARTED: HTTP_startup.sh
STARTED: probe
STARTED: fndn_udins_wrapper
STARTED: superthread_startup.sh
STARTED: /usr/wfavvid/run-wfengine.sh
STARTED: /usr/bin/launch_ums.sh
Waiting 45 ...
and then the ism gets online with the above limitations.
12-18-2012 07:48 AM
Seems like a corrupted installation that you will have to do again.
12-18-2012 07:49 AM
ahhh..
it came like this directly from cisco, it was ordered with the ism in it..
thank you for your help:)
12-18-2012 07:51 AM
All the SMs I've installed sofar needed to have software installed. Maybe now they come with this placeholder software.
Thank you for the nice rating and good luck|
