05-08-2017 03:43 AM - edited 03-17-2019 10:16 AM
Hi all,
How many CME sessions are suppoerted in ISR 4351. there is not mentionned in the datasheet
thanks in advance,
Best Regards,
MM
Solved! Go to Solution.
05-08-2017 04:00 AM
hi,
What do you mean by CME sessions? If you mean CME instances then each router support one SCCP CME and one SIP CME. However, each CME can be sliced into 5 VRFs (this is the latest number which I am aware off). This number is subject to IOS 15.5 (CME 11.5).
05-08-2017 04:39 AM
See below for help.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme116spc.html
(Rate if it helps)
JB
05-08-2017 04:00 AM
hi,
05-08-2017 04:21 AM
I mean how many phones are supported for example 3925 support 250 IP phones
05-08-2017 04:39 AM
See below for help.
(Rate if it helps)
JB
05-08-2017 08:10 AM
Thanks Bhandari for your reply.
another question the ISR 2900 series is still available or discontinued
Best regards,
MM
05-08-2017 08:39 AM
Hi MM,
They are not end of sale if you are asking that
http://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/eos-eol-notice-c51-737831.html
Table 1. End-of-Life Milestones and Dates for the Cisco 2900 Series Integrated Services Routers
Milestone |
Definition |
Date |
End-of-Life Announcement Date |
The date the document that announces the end-of-sale and end-of-life of a product is distributed to the general public. |
September 9, 2016 |
End-of-Sale Date |
The last date to order the product through Cisco point-of-sale mechanisms. The product is no longer for sale after this date. |
December 9, 2017 |
Last Ship Date: |
The last-possible ship date that can be requested of Cisco and/or its contract manufacturers. Actual ship date is dependent on lead time. |
March 9, 2018 |
End of SW Maintenance Releases Date: |
The last date that Cisco Engineering may release any final software maintenance releases or bug fixes. After this date, Cisco Engineering will no longer develop, repair, maintain, or test the product software. |
December 9, 2020 |
End of Routine Failure Analysis Date: |
The last-possible date a routine failure analysis may be performed to determine the cause of hardware product failure or defect. |
December 9, 2018 |
End of New Service Attachment Date: |
For equipment and software that is not covered by a service-and-support contract, this is the last date to order a new service-and-support contract or add the equipment and/or software to an existing service-and-support contract. |
December 9, 2018 |
End of Vulnerability/Security Support: |
The last date that Cisco Engineering may release a planned maintenance release or scheduled software remedy for a security vulnerability issue. |
December 8, 2020 |
End of Service Contract Renewal Date: |
The last date to extend or renew a service contract for the product. |
March 9, 2022 |
Last Date of Support: |
The last date to receive applicable service and support for the product as entitled by active service contracts or by warranty terms and conditions. After this date, all support services for the product are unavailable, and the product becomes obsolete. |
December 31, 2022 |
05-08-2017 09:24 AM
thanks a lot Bhandari
