ISR 4431 E1 ISDN clocking
Paul Austin
Level 4
Level 4
Hi Folks, Has anyone managed to get an E1 circuit connected to a 4th Gen Card installed in an ISR4431? I just cant get the damm thing to be stable. I suspect the clocking as when I do a "show network clocking" it is showing that it is in revertive mode which is fine I guess, but it is not showing me the source it has synced up to.
Can someone who has an E1 circuit running just show me a screenshot of the clocking status and the relevant commands in their ISR + what version of IOS they have?
I may need to upgrade the IOS but if I have a reference thats great.
Much appreciated
Paul
I have the following command too:
network-clock synchronization automatic
network-clock input-source 1 controller E1 0/1/0
network-clock input-source 2 controller E1 0/1/1
regards,
14 Replies 14
CoDeC
you need to add the command "clock source line primary" or "clock source line primary" inside of the controllers. p.e.:
controller E1 0/1/0
 pri-group timeslots 1-31 voice-dsp
controller E1 0/1/1
 clock source line secondary
regards,
Yes I already have that. although I cannot add the last part - voice-dsp
The last part is for create the "voice-port"
Like say Nipun, it'd be good share the "show controller ...." command.
You need voice-dsp keyword only if you have a T1/E1 CE card. Do a show platform or show inventory and tell me what the card is.
DPLANE EEPROM data:
        Product Identifier (PID) : ISR4431/K9
        Version Identifier (VID) : V04
        PCB Serial Number        : FOC214676KR
        Hardware Revision        : 1.0
        CLEI Code                : IPM8G00ARD
Power/Fan Module P0 EEPROM data:
        Product Identifier (PID) : PWR-4430-AC
        Version Identifier (VID) : V02
        PCB Serial Number        : LIT22012MTG
        CLEI Code                : IPUPAMFAAB
Power/Fan Module P1 EEPROM data:
        PCB Serial Number        : LIT21432EDJ
External PoE Module POE0 EEPROM data is not initialized
External PoE Module POE1 EEPROM data is not initialized
Internal PoE is not present
Slot R0 EEPROM data:
Slot F0 EEPROM data:
Slot 0 EEPROM data:
SPA EEPROM data for subslot 0/0:
        Product Identifier (PID) : ISR4431-X-4x1GE
        Version Identifier (VID) : V01
        PCB Serial Number        : JAB092709EL
        Top Assy. Part Number    : 68-2236-01
        Top Assy. Revision       : A0
        Hardware Revision        : 2.2
        CLEI Code                : CNUIAHSAAA
SPA EEPROM data for subslot 0/1:
        Product Identifier (PID) : NIM-2MFT-T1/E1
        PCB Serial Number        : FOC21432N5V
        CLEI Code                : IP9IAWBCAB
EEPROM data for slot 0 bay 1 daughter board 1
        Product Identifier (PID) : PVDM4-128
        PCB Serial Number        : FOC213564NB
        CLEI Code                : IPUCBC2BAB
SPA EEPROM data for subslot 0/2:
        Product Identifier (PID) : NIM-4FXSP
        PCB Serial Number        : FOC22092165
        CLEI Code                : IP9IAZWCAA
SPA EEPROM data for subslot 0/3 is not available
SPA EEPROM data for subslot 0/4 is not available
SPA EEPROM data for subslot 0/5 is not available
You have a non-CE card -
NIM-2MFT-T1/E1
You should be fine with the config that you already have. What is the exact issue that you have ? Clocking, slips and/or circuit flapping ?
Hi, Yes its really odd. The circuit comes up, synce with the PSTN and I start to receive calls then after ni more than 30 seconds it all resets then comes back into service a few seconds later and repeats. It is as though the clocking is not synced, but its a live service so calls end up getting disconnected. Think I'll have to get an ISDN analyser.
Thanks anyhow
Enable "debug isdn q921" and monitor. Once it flaps, collect the logs and attach it here.
R0g22
Share your configuration. T1/E1 should work absolutely fine. Clocking sync issues would generally cause slip errors.
Do a "show controller e1 x/y/z"
version 15.5
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname DGHFM-CUVG-01
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
card type e1 0 1
no aaa new-model
clock timezone GMT 0 0
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
ip domain name resource.its.local
subscriber templating
isdn switch-type primary-net5
trunk group ISDN
 description Primary Rate ISDN
 translation-profile outgoing Remove9
voice service voip
 ip address trusted list
  ipv4 10.2.130.0 255.255.255.0
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729r8
voice class sip-profiles 10
 request INVITE sip-header SIP-Req-URI modify " SIP/2.0" ";user=phone SIP/2.0"
 request REINVITE sip-header SIP-Req-URI modify " SIP/2.0" ";user=phone SIP/2.0"
voice class server-group 1
 ipv4 10.2.130.22
 ipv4 10.2.130.24
 description CUCM Subscribers
voice translation-rule 1
 rule 1 /^9\(.*\)$/ /\1/
voice translation-profile Remove9
translate called 1
voice-card 0/1
 no watchdog
license udi pid ISR4431/K9 sn FOC214676KR
redundancy
 mode none
controller E1 0/1/0
controller E1 0/1/1
vlan internal allocation policy ascending
interface Port-channel2
 ip address 10.2.130.5 255.255.255.0
 no negotiation auto
interface GigabitEthernet0/0/0
 no ip address
 negotiation auto
 channel-group 2
interface GigabitEthernet0/0/1
 no ip address
 negotiation auto
 channel-group 2
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/3
 no ip address
 shutdown
 negotiation auto
interface Service-Engine0/1/0
interface Serial0/1/0:15
 no ip address
 encapsulation hdlc
 isdn incoming-voice voice
 no cdp enable
interface Serial0/1/1:15
 no ip address
 encapsulation hdlc
 no cdp enable
 vrf forwarding Mgmt-intf
 ip address dhcp
 negotiation auto
interface Vlan1
 no ip address
 shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 10.2.130.1
control-plane
voice-port 0/1/0:15
voice-port 0/1/1:15
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
no ccm-manager fax protocol cisco
dial-peer voice 1 voip
 description incoming Dial peer from CUCM
 session protocol sipv2
 session transport udp
 incoming called-number .
 voice-class codec 1
 voice-class sip bind control source-interface GigabitEthernet0/0/0
 voice-class sip bind media source-interface GigabitEthernet0/0/0
 dtmf-relay rtp-nte
 no vad
dial-peer voice 100 voip
 description Internal extensions
 destination-pattern 3[26]....
 session server-group 1
 voice-class codec 1
 voice-class sip asserted-id pai
 voice-class sip options-ping 60
 voice-class sip options-keepalive down-interval 60 retry 3
 dtmf-relay rtp-nte sip-notify
 dtmf-interworking standard
 ip qos dscp cs3 signaling
 no vad
dial-peer voice 10 pots
 trunkgroup ISDN
 description outgoing PSTN calls
 destination-pattern 9T
 progress_ind setup enable 3
 progress_ind alert enable 8
 progress_ind progress enable 8
 forward-digits all
dial-peer voice 5 pots
 tone ringback alert-no-PI
 description inbound from PSTN
 incoming called-number 3[26]....
 direct-inward-dial
line con 0
 login local
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login local
ntp source GigabitEthernet0/0/0
ntp server 192.168.140.8
ntp server 192.169.253.9
end
regards,
OK so I have all that config in and it still fails. I'll have to get a primary ISDN tester to make sure the hardware isn't faulty. I cannot move the circuit really as its a live circuit and I am losing calls into a hospital so not ideal.
Thanks all.
It ended up been he default 300 seconds before switching to another timing source. Changed to 10 seconds and all OK.
