- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-10-2018 10:46 PM - edited 03-17-2019 12:36 PM
Hi Folks, Has anyone managed to get an E1 circuit connected to a 4th Gen Card installed in an ISR4431? I just cant get the damm thing to be stable. I suspect the clocking as when I do a "show network clocking" it is showing that it is in revertive mode which is fine I guess, but it is not showing me the source it has synced up to.
Can someone who has an E1 circuit running just show me a screenshot of the clocking status and the relevant commands in their ISR + what version of IOS they have?
I may need to upgrade the IOS but if I have a reference thats great.
Much appreciated
Paul
Solved! Go to Solution.
- Labels:
Other IP Telephony
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2018 10:47 AM
I have the following command too:
network-clock synchronization automatic network-clock input-source 1 controller E1 0/1/0 network-clock input-source 2 controller E1 0/1/1
regards,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2018 05:00 AM
you need to add the command "clock source line primary" or "clock source line primary" inside of the controllers. p.e.:
controller E1 0/1/0 clock source line primary pri-group timeslots 1-31 voice-dsp ! controller E1 0/1/1 clock source line secondary pri-group timeslots 1-31 voice-dsp
regards,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2018 08:44 AM
Yes I already have that. although I cannot add the last part - voice-dsp
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2018 08:47 AM
The last part is for create the "voice-port"
Like say Nipun, it'd be good share the "show controller ...." command.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2018 09:14 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2018 09:17 AM
DPLANE EEPROM data:
Product Identifier (PID) : ISR4431/K9
Version Identifier (VID) : V04
PCB Serial Number : FOC214676KR
Hardware Revision : 1.0
CLEI Code : IPM8G00ARD
Power/Fan Module P0 EEPROM data:
Product Identifier (PID) : PWR-4430-AC
Version Identifier (VID) : V02
PCB Serial Number : LIT22012MTG
CLEI Code : IPUPAMFAAB
Power/Fan Module P1 EEPROM data:
PCB Serial Number : LIT21432EDJ
External PoE Module POE0 EEPROM data is not initialized
External PoE Module POE1 EEPROM data is not initialized
Internal PoE is not present
Slot R0 EEPROM data:
Slot F0 EEPROM data:
Slot 0 EEPROM data:
SPA EEPROM data for subslot 0/0:
Product Identifier (PID) : ISR4431-X-4x1GE
Version Identifier (VID) : V01
PCB Serial Number : JAB092709EL
Top Assy. Part Number : 68-2236-01
Top Assy. Revision : A0
Hardware Revision : 2.2
CLEI Code : CNUIAHSAAA
SPA EEPROM data for subslot 0/1:
Product Identifier (PID) : NIM-2MFT-T1/E1
PCB Serial Number : FOC21432N5V
CLEI Code : IP9IAWBCAB
EEPROM data for slot 0 bay 1 daughter board 1
Product Identifier (PID) : PVDM4-128
PCB Serial Number : FOC213564NB
CLEI Code : IPUCBC2BAB
SPA EEPROM data for subslot 0/2:
Product Identifier (PID) : NIM-4FXSP
PCB Serial Number : FOC22092165
CLEI Code : IP9IAZWCAA
SPA EEPROM data for subslot 0/3 is not available
SPA EEPROM data for subslot 0/4 is not available
SPA EEPROM data for subslot 0/5 is not available
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2018 10:50 AM
NIM-2MFT-T1/E1
You should be fine with the config that you already have. What is the exact issue that you have ? Clocking, slips and/or circuit flapping ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2018 12:38 PM
Hi, Yes its really odd. The circuit comes up, synce with the PSTN and I start to receive calls then after ni more than 30 seconds it all resets then comes back into service a few seconds later and repeats. It is as though the clocking is not synced, but its a live service so calls end up getting disconnected. Think I'll have to get an ISDN analyser.
Thanks anyhow
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2018 01:04 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-24-2018 06:36 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2018 08:37 AM
Do a "show controller e1 x/y/z"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2018 09:21 AM
version 15.5
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname DGHFM-CUVG-01
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
card type e1 0 1
no aaa new-model
clock timezone GMT 0 0
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 2:00
ip domain name resource.its.local
subscriber templating
isdn switch-type primary-net5
trunk group ISDN
description Primary Rate ISDN
translation-profile outgoing Remove9
voice service voip
ip address trusted list
ipv4 10.2.130.0 255.255.255.0
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class sip-profiles 10
request INVITE sip-header SIP-Req-URI modify " SIP/2.0" ";user=phone SIP/2.0"
request REINVITE sip-header SIP-Req-URI modify " SIP/2.0" ";user=phone SIP/2.0"
voice class server-group 1
ipv4 10.2.130.22
ipv4 10.2.130.24
description CUCM Subscribers
voice translation-rule 1
rule 1 /^9\(.*\)$/ /\1/
voice translation-profile Remove9
translate called 1
voice-card 0/1
no watchdog
license udi pid ISR4431/K9 sn FOC214676KR
redundancy
mode none
controller E1 0/1/0
controller E1 0/1/1
vlan internal allocation policy ascending
interface Port-channel2
ip address 10.2.130.5 255.255.255.0
no negotiation auto
interface GigabitEthernet0/0/0
no ip address
negotiation auto
channel-group 2
interface GigabitEthernet0/0/1
no ip address
negotiation auto
channel-group 2
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
interface Service-Engine0/1/0
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/1/1:15
no ip address
encapsulation hdlc
no cdp enable
vrf forwarding Mgmt-intf
ip address dhcp
negotiation auto
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 10.2.130.1
control-plane
voice-port 0/1/0:15
voice-port 0/1/1:15
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
no ccm-manager fax protocol cisco
dial-peer voice 1 voip
description incoming Dial peer from CUCM
session protocol sipv2
session transport udp
incoming called-number .
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/0/0
voice-class sip bind media source-interface GigabitEthernet0/0/0
dtmf-relay rtp-nte
no vad
dial-peer voice 100 voip
description Internal extensions
destination-pattern 3[26]....
session server-group 1
voice-class codec 1
voice-class sip asserted-id pai
voice-class sip options-ping 60
voice-class sip options-keepalive down-interval 60 retry 3
dtmf-relay rtp-nte sip-notify
dtmf-interworking standard
ip qos dscp cs3 signaling
no vad
dial-peer voice 10 pots
trunkgroup ISDN
description outgoing PSTN calls
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
forward-digits all
dial-peer voice 5 pots
tone ringback alert-no-PI
description inbound from PSTN
incoming called-number 3[26]....
direct-inward-dial
line con 0
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
ntp source GigabitEthernet0/0/0
ntp server 192.168.140.8
ntp server 192.169.253.9
end
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-11-2018 10:47 AM
regards,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-12-2018 12:28 AM
OK so I have all that config in and it still fails. I'll have to get a primary ISDN tester to make sure the hardware isn't faulty. I cannot move the circuit really as its a live circuit and I am losing calls into a hospital so not ideal.
Thanks all.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-24-2018 11:41 PM
