ISR 4451 / CUBE HA collect error - %VOICE_HA-3-DATA_COLLECT_ERR: (ACTV-Call Leg Data Collect)
Peter Kuznicki
Receiving the following collector error on Active Cube:
%VOICE_HA-3-DATA_COLLECT_ERR: (ACTV-Call Leg Data Collect): HA Module SIPSPI reported DATA COLLECT failure (mainst ID:170801, CID:170801)
Receiving the following SIP-3-BADPAIR on Standby Cube:
%SIP-3-BADPAIR: Unexpected timer 24 (SIP_TIMER_REMOVE_TRANSACTION) in state 7 (STATE_ACTIVE) substate 0 (SUBSTATE_NONE)
Devices:  ISR4451-X/K9
IOS: Denali 16.3.7
HARIS_HUSSAIN
May be you are hitting below bug
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCup31708/?rfs=iqvred
To confirm the exact Bug Please open a case with Cisco TAC.
** Don't forget to rate and accept solution if helpful
Haris
5 Replies 5
This seems to be a bug. Try another IOS version
Hi Mohammed,
Do you have specific information on the bug?
HARIS_HUSSAIN
Haris
Thanks Haris
You can Rate the Post if found helpful AND If issue is resolved you can mark accept as solution.
Haris
