01-09-2016 03:04 AM - edited 03-17-2019 05:27 AM
I am deploying a Cisco ISR G3 4351 router as an ISDN PRI voice gateway.
I cannot get the ISDN interface to Multiple Frame Established.
It does not seem to be receiving responses to the SABME packets it is sending.
I am not convinced that my config is correct as the DSP and clocking setup are very different from ISR G1 and G2.
Does anyone have a ISR G3 E1 ISDN PRI config that they know works?
Thanks!
01-09-2016 04:35 AM
It was an IOS issue.
isr4300-universalk9.03.13.04.S.154-3.S4-ext.SPA.bin did not work
isr4300-universalk9.03.13.02.S.154-3.S2-ext.SPA.bin does work
The faulty IOS is later than the working one!
To configure the voice card I used the document at the link below.
01-09-2016 07:04 AM
+5..Hi James thanks for sharing this. Really good. I did send you a PM a while back. Did you get it?
01-09-2016 07:08 AM
Hi, I did get it - about the UK dial plan iirc?
Sorry I did not respond. I have been snowed under with work for the last few months.
I have a few quiet days next week and so will try to respond then.
01-09-2016 07:09 AM
Thank you.
