04-01-2013 12:56 AM - edited 03-16-2019 04:32 PM
Hi friends ,
i am facing issue in voice card which is connected on my branch router and thay always hanged ...and each and every time
when i shut these port and then no shut then port works properly
but i think it's a temporary solution ..
kindly let me know......the root cause ....and solution.
Thanks in Advanc
04-01-2013 01:02 AM
Hi Prashant,
Please let us know which is the router model/Voice card model along with IOS version u are using?
Please share output of show inventory/show diag.
regds,
aman
04-01-2013 02:24 AM
router model 2811 /voice card VIC2-4FXO
ios verson
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 15.0(1)M4 , RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 28-Oct-10 17:09 by prod_rel_team
show invent
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811 , VID: V02 , SN: FHK1017F1US
NAME: "WAN Interface Card - Serial 2T on Slot 0 SubSlot 0", DESCR: "WAN Interface Card - Serial 2T"
PID: WIC-2T= , VID: 1.0, SN: 23861607
NAME: "4 Port FE Switch on Slot 0 SubSlot 1", DESCR: "4 Port FE Switch"
PID: HWIC-4ESW , VID: V01 , SN: FOC10515V6H
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO , VID: V04 , SN: FOC150752ME
NAME: "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16 , VID: V01 , SN: FOC15076513
04-01-2013 02:29 AM
PVDM Slot 0:
16-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8538-05
Board Revision : C0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC15076513
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-16
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 EF 41 04 00 82 49 21 5A 05 42 43 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 35 30 37
0x20: 36 35 31 33 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 31 36 89 56 30 31 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
Serial 2T (12in1)
Hardware revision 1.0 Board revision D0
Serial number 23861607 Part number 800-03181-01
FRU Part Number WIC-2T=
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 12 01 00 01 6C 19 67 50 0C 6D 01 00 00 00 00
0x30: 68 00 00 00 00 11 17 00 FF FF FF FF FF FF FF FF
WIC Slot 1:
4 Port FE Switch
Base MAC Address : 0019.30f7.e84f
MAC Address block size : 4
PCB Serial Number : FOC10515V6H
Hardware Revision : 6.0
Part Number : 73-8474-06
Board Revision : A0
Top Assy. Part Number : 800-24193-02
Fab Version : 05
CLEI Code : IPUIA00RAA
RMA History : 00
Product (FRU) Number : HWIC-4ESW
Connector Type : 01
0x00: 04 FF CF 06 00 19 30 F7 E8 4F 43 00 04 C1 8B 46
0x10: 4F 43 31 30 35 31 35 56 36 48 40 00 56 41 06 00
0x20: 82 49 21 1A 06 42 41 30 C0 46 03 20 00 5E 81 02
0x30: 88 00 00 00 00 02 05 C6 8A 49 50 55 49 41 30 30
0x40: 52 41 41 03 00 81 00 00 00 00 04 00 CB 89 48 57
0x50: 49 43 2D 34 45 53 57 89 56 30 31 20 D9 02 C1 40
0x60: 05 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 2:
2nd generation - FXO Voice daughter card (4 port)
Hardware Revision : 5.0
Top Assy. Part Number : 800-33585-01
Board Revision : C0
Deviation Number : 0-0
Fab Version : 04
PCB Serial Number : FOC150752ME
RMA History : 00
Product (FRU) Number : VIC2-4FXO
Version Identifier : V04
CLEI Code : CNUIAXJAAC
0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 83 31 01
0x10: 42 43 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 35 30 37 35 32 4D 45 03 00 81 00 00 00 00 04 00
0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 34 20
0x40: C6 8A 43 4E 55 49 41 58 4A 41 41 43 FF FF FF FF
04-01-2013 02:40 AM
As you are saying that the port appears to be hung it
would suggest that you are suffereing from the
"FXO Disconnect issues"
There are loads of posts in the frum re fxo disconnect
Also read this tech note
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Alex.
Please rate useful posts.
04-01-2013 02:46 AM
this is a well known issue in FXO setup. the disconnect signal it depends on the PBX you are connected from PSTN provider. the disconnect signals are different from one vendor to other, Ericson, Siemens, Alcatel,... etc.
You need to take the appropriate disconnect signal from your PSTN provider if it is possible.
you can use the following link to look for your current disconnect signal
http://www.3amsystems.com/wireline/tone-search.htm?start=0&kCountry=92&kTone=10
if one of the above is not working you need to take pcm captures, find the below link
http://ciscoflair.blogspot.com/2009/05/cisco-fxo-disconnect-issue.html
to take pcm capture use the following command
1. Enable the capture:
Router(config t)#voice hpi capture buffer 5000000
Router(config t)#voice hpi capture destination flash:FileName.pcm.dat
2. Start the capture:
Router#test voice port x/y/z pcm-dump caplog 7
3. Place a call on that port, and disconnect from the far end.
4. After the call has been disconnected from the PSTN side, disable the capture with the command below.
Be sure to do this, or otherwise the router flash will be full and the router will hang.
Router#test voice port x/y/z pcm-dump disable
Router(config t)#no voice hpi capture destination
5. Please send me this .dat file with the bad capture so I can extract it into PCM audio files.
Anas
please rate if it is helpful
