Issue of Caller Name
ammarali
I have cme and using both sccp and sip phones  ,i have no issue in calls for both. but  my issue is on sip phones caller name, the number only appearing for incoming our out going calls. for sccp phones not issue
 here is part of configuration blocks:
Amaar#sh run | sec voice service voip
voice service voip
ip address trusted list
ipv4 172.20.0.0 255.255.255.0
ipv4 172.0.0.0 255.255.255.0
ipv4 172.0.0.0 255.0.0.0
ipv4 172.17.26.0 255.255.255.0
ipv4 172.17.27.0 255.255.255.0
ipv4 172.17.28.0 255.255.255.0
ipv4 172.17.36.0 255.255.255.0
ipv4 172.18.16.0 255.255.254.0
ipv4 10.10.16.0 255.255.255.0
ipv4 172.20.0.6 255.255.255.255
ipv4 172.20.0.5 255.255.255.255
ipv4 172.17.0.0 255.255.255.0
ipv4 172.17.1.0 255.255.255.0
ipv4 172.17.2.0 255.255.255.0
ipv4 172.17.3.0 255.255.255.0
ipv4 172.17.4.0 255.255.255.0
ipv4 172.17.5.0 255.255.255.0
ipv4 172.17.6.0 255.255.255.0
ipv4 172.17.7.0 255.255.255.0
ipv4 0.0.0.0 0.0.0.0
ipv4 172.18.0.0 255.255.0.0
ipv4 172.17.150.0 255.255.255.0
ipv4 172.16.26.29 255.255.255.255
ipv4 172.20.0.0 255.255.0.0
ipv4 172.25.135.0 255.255.255.0
ipv4 10.158.12.0 255.255.255.0
qsig decode
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
modem passthrough nse codec g711alaw
sip
subscription maximum accept 400
subscription maximum originate 400
registrar server expires max 600 min 60
Amaar#sh run | sec telephony-service
telephony-service
sdspfarm units 3
sdspfarm transcode sessions 10
sdspfarm tag 3 xcoder
conference transfer-pattern
authentication credential cisco C1sddds3c0Amaar!@#
authentication credential secretname emapp
em keep-history
max-ephones 265
max-dn 600
ip source-address 172.20.1.18 port 2000
calling-number initiator
no service directed-pickup
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message Your current option
url directories http://172.20.1.18/localdirectory
cnf-file location flash:
cnf-file perphone
time-zone 31
date-format dd-mm-yy
voicemail 7000
max-conferences 4 gain -6
call-park select no-auto-match
call-forward pattern .T
hunt-group logout HLog
moh enable-g711 "music-on-hold.au"
multicast moh 239.23.4.10 port 2000
web admin system name admin password ammardd
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 9T
transfer-pattern ....
transfer-pattern 9.T
transfer-pattern 94.......
transfer-pattern 93.......
transfer-pattern 95.......
transfer-pattern 96.......
transfer-pattern 97.......
transfer-pattern 4...
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
Amaar#sh run | sec sip-ua
sip-ua
Amaar#sh run | sec voice register global
mode cme
source-address 172.20.1.18 port 5060
max-dn 600
max-pool 265
load 8961 sip8961.9-1-1SR1.loads
load 8811 sip88xx.10-3-1-20.loads
load 8841 cmterm-88xx-sip.12-5-1SR3-74.k3.cop.sgn
authenticate register
authenticate realm local
timezone 31
date-format D/M/Y
call-forward system redirecting-expanded
voicemail 8044
url directory http://172.20.1.18/localdirectory
tftp-path flash:
file text
create profile sync 2458453513231396
camera
video
auto-register
Amaar#sh run | sec voice register pool 49
voice register pool 106
busy-trigger-per-button 2
id mac 706E.6D10.30AC
type 8851
number 1 dn 49
cor incoming CALL-ISD default
dtmf-relay rtp-nte
username Ammar password Admin
codec g711ulaw
Amaar#sh run | sec voice register dn 49
number 4204
name Sami Ahmad
label 44204204
Hi ,
Where the name is not displayed?
Please make a call example Eg.
SIP-Phone1 calls SCCP-Phone1 no Calling Name displayed
SCCP-Phone1 calls SIP-Phone1 Calling Name is  showed
Please specify also your CUCM version.
Carlo
Please rate all helpful posts "The more you help the more you learn"
