Issue registering a local gateway with Webex
noe.manuel
Good day to all of you.
10/10/2023 11:10 PM •
Im trying to register a local gateway with Webex but it is  not able to get through.
Webex hub has been configured as per the help.webex.com document and other guides provided by Cisco. The credentials generated in control hub have been configured accordingly the  the help guides.
I have attached the configuration file.
 "sip-ua register" show always  is always "no".
Is there anyone to check my config and see if can help?
Thank you
Br
Manuel
18 Replies 18
As requested earlier please post the output in an attached text file. It’s virtually impossible to work with data directly in a post.
Response Signature
txt file attached.
thank you in advance
Also please post the complete running configuration as it stands now after any changes that you have made.
Response Signature
Thank you guys for your attention.
I made a factory rest, i configured the Router again and is working.
