issue setting up pstn
rperkins
when i log into spark admin, select customer and choose setup pstn from the actions menu nothing happens. i have tried in ie11, firefox and chrome. i need to set up our numbers but cannot get the pstn page/panel to open. this is a newly provisioned spark/webex partner portal. any help appreciated. thanks
Jaime Valencia
Until now, this area is mostly geared toward on-prem deployments, not Spark, you probably want to reach out to the Spark support directly
https://support.ciscospark.com/
java
if this helps, please rate
Jaime Valencia
java
okay, will do. thanks!
