How to Best Route Calls to Unity Connection Auto Attendant
dtran
Level 6
Level 6
Hi all, hope everyone is well !!
I am looking for best recommendation on how to route incoming calls from CUCM to UnityConnection auto attendant callhandler. I've been using dummy phones and just forward all calls to UnityConnection but this method takes up licenses in CUCM. Will CTI Route point or CTI Port achieve the same results without using up licenses ?
Thanks all in advance !!!
Danny
You can also do it through CTI Route Point as that also does not consume any license.
Deepak
5 Replies 5
Aseem Anand
CTI port does not consume any license, i would suggest you to use them to forward calls to Unity connection for the Auto attendant number.
Aseem
(Please rate if useful)
Hi Aseem, thanks for your response !! I will try the CTI port and see how that goes.
Thanks !!
Danny
Deepak
Hi Deepak, thanks for your reply !!!
Danny
Glad that I was able to help Danny and thanks for marking the Correct Answer.
Deepak
