Bookmark
Subscribe
226
Issue w/ 7965 and UC 520
mumbles202
Level 5
Level 5
Adding a few 7965s to an existing UC 520 run CME 8.0 and have seen some strange behavior.  The UC already has the SCCP45.9-3-1SR1-1S loaded in the flash and configured on the phone system.  And the phones were labeled to use SR1 or higher, but they wouldn't register.  I had to do a factory reset on each of the 10 phones in order for it to register.  But even after a successful registration, if I issue a reset or a restart the phone again fails to register.  If I do a debug tftp events and debug ephone registration I see the lookup and finding of the configuration files, but it won't register.  If I unplug a phone for any considerable amount of time it does the same and I have to do a factory reset again.  Also, if I make any changes to line appearance or display name on the phone it doesn't take effect.  I have to do a factory reset.  I've tried issuing a no create cnf-files and then a create, but that didn't make much difference.
I can pull and post the config from the system if it would be helpful.  I've confirmed the .cnf file is available under system:/its.  There were 4 preexisting 7965s.  I noticed after I made a change on one of them and restarted it it wouldn't register and I had to factory reset it.  The 3 other phones are running the same version of firmware, but the older boot load file.  They don't seem to be exhibiting this behavior.
Hi David,
Could you please post the config from the system?
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
please find the config attached.
