Issue with Wireless Plantronics headset with Cisco 7962 IP Phone
AK
Issue :
- Issue with Wireless Plantronics headset with Cisco 7962 IP Phone
- User's Cisco IP Phone 7962 firmware SCCP42.9-4-2SR3-1S is facing issues while picking up calls (Primary as well as Secondary) with the help of headset.
- Wireless option on the phone page already enabled.
- All user facing this issue.
- Headset tried with other phone but it remains same.
- Coming in call cannot get answered via the headset
- Physical phone without headset is working well
- Same kind of wireless headset showed the same issue
- Tested User's headset during the call – not working at all – even if battery is fully charged
- Suggestion to get User’s phone firmware upgraded to the version User's working phone currently have.
- When User is on the phone with her own headset and a 2nd call comes in, she cannot take the 2nd call as the headset disconnects current call and 2nd call fails, too
- User is then testing working phone with his own headset, too. Outcome: same problem as before
- Unaffected user then testing functionality with his own phone and headset. Outcome: same problem
- Major problem is intermittently that Affected user, when using headset, cannot take any call
Please help.
Rob Huffman
Hi AK,
Can you please let us know the model of Plantronics headset and the model/part number of the APC (link below for example) cord you are using with the headset base.
http://www.plantronics.com/ca/product/apc-42
Cheers!
Rob
Hi Rob,
Thanks for your response.
The headset model is Plantronics C052A.
You can also consider the attached screenshot for reference.
bsihelpdesk
Did you ever find a resolution to this issue? I think some of my users may be experiencing it.
