ITSP-SIP-CUBE-SIP-CUCM
ashraf1891
Inbound call not connecting:
calling number 559903358
called number +966114817200 (translated to 7200)
________________________________________
below is my dial peers:
dial-peer voice 3 voip
description LOCAL-CALLS-1
translation-profile outgoing OUT
destination-pattern .T
session protocol sipv2
session target dns:fmc.stc.com.sa
session transport udp
voice-class codec 1
voice-class sip early-offer forced
voice-class sip bind control source-interface GigabitEthernet0/1
voice-class sip bind media source-interface GigabitEthernet0/1
dtmf-relay rtp-nte sip-notify
no vad
dial-peer voice 1 voip
description TO-CUCM-PUB
destination-pattern ^[1-9]...
session target ipv4:172.30.2.10
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/0
voice-class sip bind media source-interface GigabitEthernet0/0
dial-peer voice 2 voip
description TO-CUCM-SUB
preference 1
session target ipv4:172.30.2.11
voice-class codec 1
dial-peer voice 4 voip
translation-profile incoming IN
incoming called-number +966.T
voice-class codec 1
no vad
attached is  the Debug CCSIP Messages
36 Replies 36
Please find the attached debug file
I see the CUBE is receiving 503 Service Unavailable from CUCM server. This CUCM server is unable to process the call. If you want to find which CUCM is this, then check session target IP in  Dial-peer 12.
Jul 26 10:08:32.323: //3022/33C860448DC2/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 503 Service Unavailable
Via: SIP/2.0/UDP 10.228.56.90:5060;branch=z9hG4bKB813F2
From: <sip:+966557514861@fmc.stc.com.sa>;tag=A8785E3-D88
To: <sip:8348@10.228.56.96>;tag=180~fbe964ed-730f-4251-b1fb-bdb3cac95554-44731732
Date: Wed, 26 Jul 2023 10:08:29 GMT
Call-ID: 33C9E6A8-2AD311EE-8DC890AF-3E64217C@10.228.56.90
CSeq: 101 INVITE
Allow-Events: presence
Reason: Q.850;cause=47
Server: Cisco-CUCM11.5
Session-ID: bd8360ec6dbf7dc9429226ba44731733;remote=5a6291272b8e54ee8d46c403516c35ae
Content-Length: 0
dial-peer 12 is pointing to Call Manager publisher and  IP phone is ringing and when you try to answer the call it become unresponsive and we are not able to hear ring on mobile.
It could be related to media resource not available as call is disconnecting with CV 47. I see in the logs that the endpoint is ringing. The issue could be due to codec mismatch.
Outgoing calls
Just to be clear I’m not saying that content of the Req-URI is the issue that you have. The shared information in the debug does not indicate that.
Based on an error seen in the debug, “SIP: Trying to parse unsupported attribute at media level”, this post seems to be similar to what you’re seeing. https://community.cisco.com/t5/ip-telephony-and-phones/sip-trying-to-parse-unsupported-attribute-at-media-level/td-p/2861872
One thing suggested there is to check that the SIP security profile is set to the protocol that you have set in the gateway, ie UDP from the look of shared information.
Response Signature
TechLvr
@ashraf1891
From the SIP logs you shared, it is evident that the CUCM cluster does not respond to the incoming SIP invites from the CUBE.
On the SIP Trunk configuration page, can you verify that the "Run On All Active Unified CM Nodes" box is checked? You did not capture that field in the screenshots you shared. Make sure you reset the SIP trunk after making any changes.
If SIP trunk runs on all active nodes and incoming calls issue still persists, then make sure that the CallManager service is running on both 172.30.2.10 and 172.30.2.11. There may be a third CUCM node in your cluster that handles internal and outbound calls but when it comes to inbound calls, you are only pointing them to two nodes which may not have the CallManager service running.
