IP Telephony and Phones
Labels
Hello,I have an ISR 2911 with the IOS 15.3(3)M5. This gateway is configured to allow SIP Phones to register in case of a CUCM failure using the eSRST mode.Here is the configuration:voice register global mode esrst system message "Mode SRST" max-dn 20...
Thomas P by Level 1
  • 3786 Views
  • 10 replies
Dear All,   I would like to use the new-ish CUBE multivrf feature (documented here). One of the limitations is: Multi-VRF is not supported on TDM-SIP gateway What is actually meant by this? If I wanted to run say an MGCP controlled NIM-4FXS on the sa...
j.a.m.e.s by Level 4
  • 2580 Views
  • 12 replies
Good Afternoon,  I have a ticket open with Grandstream for thier DP750/720 cordless VoIP DeCT devices on my CUCM 11.5 cluster.  Background is that no matter what a customer sets as the ringtone on the handsets, incoming calls ring using the system to...
RAustin70 by Level 1
  • 2701 Views
  • 6 replies
