IVR not accepting DTMF for the SIP DIDs when dialing any call center
mohsin majeed
Level 2
Level 2
Hi Dears,
In a project I have SIP and E1 trunk.
- When a user dials any call center or 800 or 9200 service numbers. After listening the greetings it is asked like to press 1 and 2 for the language selection or any other option. This ivr dialed digit have no effect.
- For E1, it is working fine with no issue.
need help
Here is the issue:
Your ITSP is using payload 97 for rtp-nte and cisco uses 101.
m=audio 48302 RTP/AVP 8 0 18 4 2 98 99 97
a=rtpmap:97 telephone-event/8000
a=fmtp:97 0-15
To resolve this please configure the following:
conf t:
rtp payload-type cisco-codec-fax-ack 98
rtp payload-type nte 97
Please rate all useful posts
10 Replies 10
vinodkewate
Change your DTMF Signalling method on trunk to RFC 2833.
Thanks vinod for your reply
 i will be keep posting the result when visit the site
I tried with both DTMF methods (RFC 2833, OOB and RFC 2833) nothing happened :(
Also i selected Accept unsolicited notification from SIP security profile and reset the trunk.
Any other suggestion please
Can you please attach your sh run. Can you also describe the elements in your call flow.
ie phone(sccp or sip)---cucm---sip--cube--sip--itsp ?
sh run is attached
Call flow is same as
Phone SCCP/SIP (sip DID)--> CUCM (Siptrunk)-->cube-->sip--> ITSP
i tried with both phone config(sccp/sip), but same issue
Can you remove the following from your dial-peers
voice-class sip dtmf-relay force rtp-nte
Then enable the ff debugs and do another test call
debug voip ccapi inout
debug ccsip messages
Please attach the debugs and include the calling and called number
i removed "voice-class sip dtmf-relay force rtp-nte" from all dialpeer
ccsip and ccapi debug is attached
Calling DID : 2835423
called number : 0907      ( 907 is saudi telecom service number)
Here is the issue:
a=fmtp:97 0-15
conf t:
can u please help me on this issue also
I remember you worked on "SIP/2.0 484 Address Incomplete" before with me
here is the detail
https://supportforums.cisco.com/discussion/12399606/call-forward-all-offnet-offnet-not-working
mohsin majeed
Level 2
Level 2
Dear Ayodeji,
You saved my life second time :)
simply love you
Thanks alot again
