Jabber 14 - set default appearance
Hiep Bui
We are deploying Jabber v14.1 to our Contact Center agents. How can we set the default appearance of Jabber to Classic? Any parameter we can set in the msi file for such purpose? The Jabber is used only for phone calls and it should be as compact as possible.
b.winter
Check the parameter reference guide, if there is a parameter for that.
There is a parameter for that, but it is configured in the xml config file. I wonder if there is a key to set it when installing the software.
You could customize the parameters in the MSI file and repackage it again.
