Jabber Connectivity VIA VPN
DEAR ALL EXPERTS;
I HAVE SUCCESSFULLY DEPLOYED IM PRESENCE WITH JABBER, INTERNALLY ITS WORKING FINE. FROM OUTSIDE ACCESS I GOT TO KNOW THAT ANYCONNECT VPN WILL HELP ....
CAN ANYONE HELP ME ? HOW TO CONFIGURE ANYCONNECT VPN ON CISCO ASA FIREWALL . DOES IT REQUIRE ANY SSL CERTIFICATION ?
PLEASE HELP ME ......
6 Replies 6
Chris Deren
You might have better luck posting your question under the security--> firewall forum, as this one is trcikly for voice related issues.
Chris
George Thomas
Level 10
Level 10
You could look into Expressway C/E for VPNless Jabber. Its a $0 virtual appliance that needs to be ordered from Cisco.
Please rate useful posts.
Hi George Thomas;
its a device or software. Its free u mean ... i can download using TAC login id. Please tell me in detail sir.
Its a server which can be virtualized. You will  have to order it.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/expressway-series/datasheet-c78-730478.html
The top level part number is R-UCL-UCM-LIC-K9. You will need CUCM 9.1.2 or higher with CUPS to get it working.
Thanks for reply. Last question is it free or I will have to buy ....
Yes its free.
